• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Navisworks API
    Active Member
    SergioFA
    Accepted Solution
    3th party apps VS 2010 Color
    262 Views, 8 Replies
    01-04-2012 08:48 PM
    HI all
    This time i really need your help. I am traying change the color of an object. Let me explain please.
    1. Select a button that has the next code Autodesk.Navisworks.Api.Application.ActiveDocument.Tool.Value = Autodesk.Navisworks.Api.Tool.Select;
    2. I select a object (pipe) and then ...
    3. Press the other button to change the color of that object.
    I dont have much experience.... please help me. Attached a screenshot.
    Regards
    Sergio Franco.
    Please use plain text.
    KempCE
    Re: 3th party apps VS 2010 Color
    01-05-2012 06:13 AM in reply to: SergioFA
    Sergio,
      See If This Works
    //Begin Code
    using NavAPI = Autodesk.Navisworks.Api;
    // m_Color should be the Color Selected example: #FFFFFF
    System.Windows.Media.Color m_CompColor =(Color)System.Windows.Media.ColorConverter.ConvertFromString
    		m_Color
    NavAPI.Application.ActiveDocument.Models.OverridePermanentColor
    NavAPI.Application.ActiveDocument.CurrentSelection.SelectedItems,
    	new NavAPI.Color
    		Convert.ToDouble(m_CompColor.R) / 255,
    		Convert.ToDouble(m_CompColor.G) / 255,
    		Convert.ToDouble(m_CompColor.B) / 255
    //End Code
    KempCE
    01-05-2012 08:34 AM in reply to: KempCE
    Sergio,
     I forgot to add this line of Code at the Very end
    NavAPI.Application.ActiveDocument.CurrentSelection.Clear();
    Colin
    Active Member
    SergioFA
    01-05-2012 08:48 AM in reply to: KempCE
    KempCE
    Just one error appears, "m_color does not exist in the current context" for try if this works. Help me please...
    SF
    KempCE
    01-05-2012 08:50 AM in reply to: SergioFA
    Sergio,
    In your picture you showed a Button with a Color that the User Selects to change the color. Change m_Color to that Color Selection
    Colin
    Active Member
    SergioFA
    01-05-2012 10:07 AM in reply to: KempCE
    KemCE
    the code is..
    string color = "RED";
                System.Windows.Media.Color m_CompColor = (System.Drawing.Color)System.Windows.Media.ColorConverter.ConvertFromString
                    (color
                Autodesk.Navisworks.Api.Application.ActiveDocument.Models.OverridePermanentColor
                Autodesk.Navisworks.Api.Application.ActiveDocument.CurrentSelection.SelectedItems,
                    new Autodesk.Navisworks.Api.Color
                Autodesk.Navisworks.Api.Application.ActiveDocument.CurrentSelection.Clear();
    when i change m_color by color that is "string color  ="RED;".  Appears an error "Cannot implicity convert type"System.Drawing.Color" to "System.Windows.Media.Color" ". Please am i doing something wrong??
    SF
    KempCE
    01-05-2012 10:48 AM in reply to: SergioFA
    Sergio,
      you will need the R,G,B Hex Color String.
    Red = #FF0000
    Colin
    Active Member
    SergioFA
    01-05-2012 07:00 PM in reply to: SergioFA
    Colin
    Thanks a lot, again...
    here is the code
    System.Drawing.Color c = System.Drawing.Color.Red;
                string strcolor = System.Drawing.ColorTranslator.ToHtml(c);
                //Autodesk.Navisworks.Api.Application.ActiveDocument.Models.OverridePermanentColor(IEnumerable<ModelItem>, Autodesk.Navisworks.Api.Color.Red);
                System.Windows.Media.Color m_CompColor = (System.Windows.Media.Color)System.Windows.Media.ColorConverter.ConvertFromString
                    (strcolor
    SF
    Active Member
    SergioFA
    01-09-2012 10:52 AM in reply to: SergioFA
    Colin
    I am very grateful for your help. Please could you help me with the next.
    I am trying to use the function "HIDE UNSELECTED" from my app. I try with the next...
            private void button14_Click(object sender, EventArgs e)
           Autodesk.Navisworks.Api.Application.ActiveDocument.Models.SetHidden(Autodesk.Navisworks.Api.Application.ActiveDocument.CurrentSelection.SelectedItems, true);
    but the result is other. How can i do it??
    Please Help.
    Best Regards,
    SF
