3th party apps VS 2010 Color
Message 1 of 9
HI all
This time i really need your help. I am traying change the color of an object. Let me explain please.
1. Select a button that has the next code Autodesk.Navisworks.Api.Application.ActiveDocument.Tool.Value = Autodesk.Navisworks.Api.Tool.Select;
2. I select a object (pipe) and then ...
3. Press the other button to change the color of that object.
I dont have much experience.... please help me. Attached a screenshot.
Regards
Sergio Franco.
Replies (8)
Message 2 of 9
Sergio,
  See If This Works
//Begin Code
using NavAPI = Autodesk.Navisworks.Api;
// m_Color should be the Color Selected example: #FFFFFF
System.Windows.Media.Color m_CompColor =(Color)System.Windows.Media.ColorConverter.ConvertFromString
		m_Color
NavAPI.Application.ActiveDocument.Models.OverridePermanentColor
NavAPI.Application.ActiveDocument.CurrentSelection.SelectedItems,
	new NavAPI.Color
		Convert.ToDouble(m_CompColor.R) / 255,
		Convert.ToDouble(m_CompColor.G) / 255,
		Convert.ToDouble(m_CompColor.B) / 255
//End Code
Message 3 of 9
Sergio,
 I forgot to add this line of Code at the Very end
NavAPI.Application.ActiveDocument.CurrentSelection.Clear();
Colin
Message 4 of 9
KempCE
Just one error appears, "m_color does not exist in the current context" for try if this works. Help me please...
SF
Message 5 of 9
Sergio,
In your picture you showed a Button with a Color that the User Selects to change the color. Change m_Color to that Color Selection
Colin
Message 6 of 9
KemCE
the code is..
string color = "RED";
            System.Windows.Media.Color m_CompColor = (System.Drawing.Color)System.Windows.Media.ColorConverter.ConvertFromString
                (color
            Autodesk.Navisworks.Api.Application.ActiveDocument.Models.OverridePermanentColor
            Autodesk.Navisworks.Api.Application.ActiveDocument.CurrentSelection.SelectedItems,
                new Autodesk.Navisworks.Api.Color
            Autodesk.Navisworks.Api.Application.ActiveDocument.CurrentSelection.Clear();
when i change m_color by color that is "string color  ="RED;".  Appears an error "Cannot implicity convert type"System.Drawing.Color" to "System.Windows.Media.Color" ". Please am i doing something wrong??
SF
Message 7 of 9
Sergio,
  you will need the R,G,B Hex Color String.
Red = #FF0000
Colin
Message 8 of 9
Colin
Thanks a lot, again...
here is the code
System.Drawing.Color c = System.Drawing.Color.Red;
            string strcolor = System.Drawing.ColorTranslator.ToHtml(c);
            //Autodesk.Navisworks.Api.Application.ActiveDocument.Models.OverridePermanentColor(IEnumerable<ModelItem>, Autodesk.Navisworks.Api.Color.Red);
            System.Windows.Media.Color m_CompColor = (System.Windows.Media.Color)System.Windows.Media.ColorConverter.ConvertFromString
                (strcolor
SF
Message 9 of 9
Colin
I am very grateful for your help. Please could you help me with the next.
I am trying to use the function "HIDE UNSELECTED" from my app. I try with the next...
        private void button14_Click(object sender, EventArgs e)
       Autodesk.Navisworks.Api.Application.ActiveDocument.Models.SetHidden(Autodesk.Navisworks.Api.Application.ActiveDocument.CurrentSelection.SelectedItems, true);
but the result is other. How can i do it??
Please Help.
Best Regards,
SF
