• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Moldflow Adviser
    New Member
    ajlprescott
    create fan gate
    1129 Views, 4 Replies
    08-25-2010 07:32 AM
    is it possible for me to create a fan gate in Moldflow Plastics Adviser?
    Product Support
    Re: create fan gate
    08-31-2010 02:45 AM in reply to: ajlprescott
    for a fan gate you have to model it in cad as a part of cavity(part)model before importing to Adviser.
    This is due to the fact that the fan gate width is normally much wider than a regular tab gate, and no fan gate
    modeling available in current release.
    Berndt
    Berndt Nordh
    Moldflow Support Specialist
    Product Support
    Autodesk, Inc.
    Member
    Re: create fan gate
    09-01-2010 03:44 PM in reply to: ajlprescott
    I have created fan gates using the tapered gate option.  Seemed to work well.
    New Member
    Re: create fan gate
    07-07-2011 08:43 PM in reply to: bjdavison
    crearting a fan gate using moldflow software is a dull work, moldflow should develop certain functions for flexiblae modelling.
    in moldflow, the connection between beam and product model is always a issue for application.
    Product Support
    Re: create fan gate
    07-08-2011 02:27 AM in reply to: yj0707
    it would be good to have fan gate modeling within Moldflow Adviser.
    As not available in current release, a way to do this can be suggested:
    With the release of Autodesk Moldflow Adviser 2012 more options of modeling has been introduced.
    There is now an interoperability between Autodesk Moldflow Adviser 2012 and Inventor Fusion 2012, that can be used to model fan gate.
    First, install:
    - Autodesk Moldflow Adviser 2012
    - Autodesk Moldflow Design Link 2012: supports Autodesk Inventor 2012 .ipt and SAT -format (no license required)
    - Autodesk Inventor Fusion 2012 (on same computer as Autodesk Moldflow Adviser 2012)
    Import the model to Autodesk Inventor Fusion 2012 in file format of such as:
    ipt, SAT, parasolid, step, CATPart, sldprt, prt
    After modeling fan gate in Inventor Fusion, export as SAT, and import to Moldflow Adviser
    Attach a file to show what it can look like.
    Berndt
    Berndt Nordh
    Product Support
    Autodesk, Inc.
