• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Moldflow Adviser
    New Member
    weslsmit1
    Warp Analysis
    215 Views, 1 Replies
    10-10-2011 08:55 AM
    Where is the best spot on a part to set up the anchor plane.  After placing the 3 points the results can drastically change
    Product Support
    Re: Warp Analysis
    10-10-2011 11:36 PM in reply to: weslsmit1
    this is depends of course of part design, and how the result needs to be interpreted for the part design.
    One have to consider the position of the anchor plane carefully when viewing warpage results.
    Locate the plane across a flat part section where one can easily visualize the deflections, and where the implications of the deflections can be most clearly interpreted.
    The possible locations for an anchor plane include the following:
    - The base of a part that is required to lie flat on a surface.
    - The joining plane to a mating component.
    - The feet of the part.
    Select the three points over a large area to define an easily visualized reference plane.
    If the three points are close, smaller area, the results can change drastically.
    Keep in mind: the warp analysis result is the same for the part - using anchor plane is another way to plot and view the result.
    Berndt
    Berndt Nordh
    Moldflow Support Specialist
    Product Support
    Autodesk, Inc.
