• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Moldflow Adviser
    Member
    Spencedaddy
    Moldflow will not calculate suitability
    296 Views, 5 Replies
    08-30-2011 09:39 PM
    my moldflow will not calculate suitability....anybody got any sort of idea on where to go from here?
    i'm so lost I can't even describe it!
    2.3Ghz Processor not enough?
    Product Support
    Re: Moldflow will not calculate suitability
    08-30-2011 11:43 PM in reply to: Spencedaddy
    there is to less information to understand what is going on.
    As you mention "calculate suitability", I assume you run in Autodesk Moldflow Adviser, right?
    There is an option in Autodesk Moldflow Adviser when importing model, to "Check suitability".
    Un-tick it and rei-mport to see in model is read in, as this issue might be model quality related.
    Re. system requirements, have a look at:
    http://usa.autodesk.com/moldflow/system-requirements/
    Berndt
    Berndt Nordh
    Moldflow Support Specialist
    Product Support
    Autodesk, Inc.
    Member
    Spencedaddy
    08-31-2011 08:07 AM in reply to: nordhb
    what do you mean the model would not be high enough quality? its a very simple piece, a handle to be exact.
    Every time I try to have a suggested gate on the part, it gets stuck at either "calculating suitability", or "processsing model" it gets stuck like this for hours
    my laptop specs are
    AMD Turion Dual core 2.3Ghz processor
    4.0GB of Ram
    Windows 7
    maybe this is not enough computing power to simulate moldflow in a part even this simple?
    Product Support
    08-31-2011 10:40 PM in reply to: Spencedaddy
    it seems as your hardware specification is enough, as you write it is a simple piece.
    But a simple piece can have model quality issues as well.
    Which release of Autodesk Moldflow Adviser are you running?
    Can you supply the model?
    Berndt
    Berndt Nordh
    Product Support
    Autodesk, Inc.
    Member
    Spencedaddy
    08-31-2011 11:57 PM in reply to: nordhb
    hmmm...could all of this be the fact that i'm running on an educational license? as opposed to a full purchased version? (student currently)
    there is the part....its pretty simple as far as handles go, so i don't know exactly what is going wrong....
    maybe everything did not install correctly or i did not register everything correctly with having my educational license only?
    Product Support
    09-01-2011 01:32 AM in reply to: Spencedaddy
    thank you for attaching the model.
    The model imports fine in native .ipt format to Autodesk Moldflow Adviser 2012, it runs and completes as expected.
    Imported the model to Inventor Fusion, created a stl-file, and it to Autodesk Moldflow Adviser 2012, it runs and completes as expected.
    Ran a 3D analysis, and it completes within 5 minutes.
    I am not aware of limitations in the student version. Your model should pass.
    Please, contact the Education Community Support Team at
    http://students.autodesk.com/?nd=problem_form
    for further help and troubleshooting.
    Further, Autodesk Moldflow Adviser has a forum of its own at:
    http://forums.autodesk.com/t5/Autodesk-Moldflow-Adviser/bd-p/365
    Berndt
    Berndt Nordh
    Product Support
    Autodesk, Inc.
