• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Moldflow Adviser
    New Member
    KurtBaker8050
    Moldflow Adviser 2010, how to setup the add-in option in Solidworks 2011
    485 Views, 1 Replies
    04-12-2011 09:40 AM
    How do I add Moldflow to the "add-ins" in Solidworks 2011? I went to tools, add-ins..., and there is no selection to start the Moldflow add-in. I have Win7x64 with Moldflow Adviser 2010x64 loaded.
    Thanks.
    K.B.
    New Member
    KurtBaker8050
    Re: Moldflow Adviser 2010, how to setup the add-in option in Solidworks 2011
    04-21-2011 08:39 AM in reply to: KurtBaker8050
    Found out when 2010 Advisor SP1 is installed it loads the Add-in option in Solidworks 2011.
    If you updated to 2010 Advisor R2 SP1 it will not install the add-in and will remove the Add-in from the prior version.
    So you must use the STL import option, just a few more steps.
