• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Moldflow Adviser
    New Member
    fabio.caires
    Integration CAD and AMA
    130 Views, 4 Replies
    11-16-2011 04:09 AM
    Hi, someone has experience using PTC CAD files with Autodesk moldflow Adviser?
    compatibility, quality of imported files, quality of the mesh generated, etc..
    Active Member
    mtessier
    Re: Integration CAD and AMA
    11-16-2011 08:08 AM in reply to: fabio.caires
    Hi Fabio,
    I have experience importing CAD models from ProEngineer Wildfire 4.0 to AMA and AMI.
    I use Autodesk CAD Doctor for ProEngineer to deal with all model issues and simplification.
    Using CAD Doctor, compatibility is good and imported files are good.  Regarding the quality of the mesh, AMA does the meshing for you based on the imported solid geometry, so as long as your CAD model is good, there is limited difference between using Inventor or ProEngineer.
    Hope this helps.  Feel free to send me a message if you have additional questions.
    Matt
    New Member
    fabio.caires
    11-16-2011 08:45 AM in reply to: mtessier
    Hi Matt!
    thanks a lot, just another question, do you know if there is a plug-in for AMA/Pro-E, like Inventor has?
    Active Member
    mtessier
    11-16-2011 08:55 AM in reply to: fabio.caires
    Hi Fabio,
    The plug-in you're looking for is Autodesk Moldflow Design Link for ProEngineer.  It allows you to import native ProE files to AMA or CAD Dr.  CAD Dr. can then be used to export .UDM files to AMA and AMI if there are model issues.
    Matt
    Product Support
    11-16-2011 12:24 PM in reply to: mtessier
    just to mention that there is an Autodesk Moldflow Adviser application for Pro/Engineer, it this is what you are looking for.
    Please, have a look at:
    http://forums.autodesk.com/t5/Autodesk-Moldflow-Adviser/Adviser-application-for-Pro-Engineer-is-avai...
    It is actually in top of this forum.
    Berndt
    Berndt Nordh
    Moldflow Support Specialist
    Product Support
    Autodesk, Inc.
