• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Moldflow Adviser
    New Member
    anoukh
    Importar .iges* con moldflow adviser
    643 Views, 3 Replies
    10-19-2010 06:51 AM
    Cómo hago para comenzar un nuevo proyecto con moldflow adviser si el archivo que tengo es extensión .iges*?
    Necesito un programa extra? tiene licencia independiente que el programa que yo uso?
    Pleasee! Respesta!
    Product Support
    Re: Importar .iges* con moldflow adviser
    10-25-2010 12:16 AM in reply to: anoukh
    Autodesk Moldflow Adviser reads stl files by default.
    To read other formats such as iges, step, parasolid, Pro/E, sdlprt, CatiaV5 you need Autodesk Moldflow Design Link,
    which comes in 3 flavours depending on cad system.
    Advice you to contact your local reseller.
    Berndt
    Berndt Nordh
    Moldflow Support Specialist
    Product Support
    New Member
    ryanw
    07-22-2011 08:49 AM in reply to: nordhb
    I am looking for somemore information on your response.
    we have Autodesk MoldFlow Adviser 2012 and you are stating we need MoldFlow Design Link to upload iges, step, ProE files.  when you state that does Adviser up load the native step, iges, ProE, etc. files without having to do any converting?
    where do I find more infromation on this "Design Link" software
    One other question I have is AutoDesk Inventor Fusion included with MoldFlow Adviser 2012?  If so where do I need to go get that because when we installed Adviser 2012 we didn't see anything on the Fusion software.
    Thanks!!
    Employee
    07-28-2011 07:17 AM in reply to: anoukh
    Note that :
    - Without Autodesk Moldflow Design Link, you can import iges curve to modelize runner and cooling lines. Look fo rimport runner or cooling lines.
    - Autodesk Moldflow Design Link and Fusion can be install from the installation DVD, or if you didn't receive it, youc an download it from the subscription center.
    Contact your reseller for more information.
    Yannick
