• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Moldflow Adviser
    New Member
    darken98
    AutoDesk MoldFlow Adviser - Hung on Splash Screen
    102 Views, 1 Replies
    12-02-2011 06:52 AM
    Hi, as title subject says
    It's a new install on a new machine, pulling a license from a license server, double click the icon, get the initial splash screen and it hangs there.
    CTRL-ALT-DEL shows advisor.exe with pc use.
    I'm not an expert on Autodesk.  Is there a quick fix for this?
    Uninstalled and reinstalled and getting the same thing.
    Thanks!
    Product Support
    Re: AutoDesk MoldFlow Adviser - Hung on Splash Screen
    12-02-2011 11:26 AM in reply to: darken98
    the reason is probably that the project folder is for a specific user on network.
    Two options here I would say:
    1- During installation, point working directory to a local folder such as "C:\My AMA 2012 Projects" reachable by all.
    2- Create directory manually and change registry manually
    If you are confident to manually change the registry you can do as follows:
    Create a local folder via Windows Explorer and name such as C:\My AMA 2012 Projects
    Change MPA_USER_HOME in regedit
    Start > Run
    regedit <enter>
    find: HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Moldflow Adviser\2012\Environment
    modify MPA_USER_HOME to hold the created local folder such as C:\My AMA 2012 Projects.
    Exit regedit
    Start Adviser
    Note: option 2 means you will not get subdirectories created
    You can copy those manually from a previous release folder such as C:\My AMA 2011 Projects.
    To change start directory from Adviser user interface:
    Top left: M > Options, tab Directories
    Hope this helps.
    Berndt
    Berndt Nordh
    Moldflow Support Specialist
    Product Support
