• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Mechanical Desktop
    Active Member
    Why does autosave turn off?
    736 Views, 6 Replies
    10-08-2005 07:18 AM
    It has happened at random, I notice that my Autosave, (set for 15min) is turned off and I have to go to options again and reset it. Has anyone ever ran into this & why? Using MDT6.
    RIck Hamlin
    Please use plain text.
    *just havin a ball
    Re: Why does autosave turn off?
    10-08-2005 04:34 PM in reply to: rdhdesign
    > It has happened at random ...
    Wonder if it's like the DIA sisters; CMD, FILE & ATT (if that was their names;
    homely bunch anyway)? Gets toggled off by some function then you crash and it
    has to be re-set manually?
    _ _ _ _
    The rest is just for fun...
    Being as fond of inflammatory statements as any red blooded boy; if you have
    intentions of moving on to a modern, parametric CAD system someday you might
    want to wean yourself of the autosave function. That system probably won't have
    one.
    I normally don't use autosave with any app, but tried running it in MDT (tried
    a few times with different versions up thru MDT6) and turned it back off because
    I felt very strongly that it was Causing Random Crashes.
    Valued Contributor
    10-08-2005 05:57 PM in reply to: rdhdesign
    I don't know your specific situation. Work off your hardrive and save to the server when needed. Working with a server
    can cause a lot of unexpected crashes.
    (just an old fashioned suggestion)
    Active Member
    10-10-2005 07:23 AM in reply to: rdhdesign
    Thanks for the reply guys. Thought maybe there was some others who had the problem. Can't find why it turns those "sisters" off.
    I would switch to the better software if my customers would. I have already purchased new Inventor, & MDT, but can't save backward. Everything should be universal, but you know how that is.
    Thanks again, anyway
    Rick Hamlin
    New Member
    Johnny_Kage
    01-31-2012 09:02 AM in reply to: rdhdesign
    I have had this problem for years, since AutoCAD 2004 (currently on 2011 MEP).  I go in to the options, turn it on and set it for 10 minutes.
    A couple months later, when AutoCAD crashes, I go to my autosave folder, and the latest sv$ file is a month old.  Then I go to the options, and the automatic save function is unchecked again.  WFT?!
    Distinguished Mentor
    ampster
    02-01-2012 07:17 AM in reply to: Johnny_Kage
    Could it be when Acad crashes, it forgets that option?
    Window For Tournaments?
    Please, not on this forum.
    New Member
    Johnny_Kage
    02-01-2012 07:33 AM in reply to: ampster
    Don't be hatin' on Tournaments.  LOL, sorry.  That was supposed to be a ...
    It's a plausable explanation, but it seems to stop doing that for a long time (months).  It happened to me yesterday, and the latest save was from November.
    Edited by
    Discussion_Admin
