Autodesk Mechanical Desktop
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
*Dupre, Joe
What's up with the new dimension scale in MDT6???
Options
- Highlight
- Email to a Friend
55 Views, 9 Replies
09-20-2001 04:33 AM
Can someone please explain the rationale of MDT 6 forcing DIMSCALE to 1
when placing dimensions in drawing view?
For years I have used a dimension style that I use on all drawings, and I
set the overall scale for dimensions depending on the size of the drawing.
But now MDT6 always puts an override on dimscale to 1.
The solution, I have read, is to goto AMOPTIONS and set the layout scale.
This is a horible solution as it forces me to deal with layouts that are not
1:1.
Is the a way to tell MDT6 to use a specific dimscale other than by changing
the scale for the entire layout???
Muchos gracias,
- Jose
1:1.
Muchos gracias,
- Jose
Re: What's up with the new dimension scale in MDT6???
Options
- Highlight
- Email to a Friend
09-10-2008 11:19 PM in reply to:
*Dupre, Joe
Having the same problem in MDT 2009
And i agree changing the layout scale in AMOPTIONS isn't a good solution.
Nobody ever came up with a proper solution?
*Alex
Options
- Highlight
- Email to a Friend
09-12-2008 04:52 AM in reply to:
*Dupre, Joe
I been working with MDT6.0 for years - never had any problems.
Al
wrote in message news:6028778@discussion.autodesk.com...
Al
Options
- Highlight
- Email to a Friend
09-14-2008 10:43 PM in reply to:
*Dupre, Joe
So you mean that changing the overall scale of your dimstyle would directly update all your dimensions?
When placing new dimensions the OVERALL DIM SCALE setting (on the FIT-tab in DIMSTYLE) is being ignored and it just used the value 1. (Just to make clear, I am talking about the size of the dim text and arrows)
It does accept other changes, like color, arrow style, textheight etc. But it just ignores the overall scale setting...
After I typ in the command line : DIM, UP, ALL it does update though
From then it seems to follow all changes in DIMSTYLE settings box.
I am using my own personalised style. Which has been set in AM
TANDARDS under DIMENSION: SETTINGS
When doing a multi edit (AMDIMMEDIT) to change the "precision" on multiple dims, only the first selected dim updates. Additional text does get added to all of them...
It very well could be a specific setting but where to find it? I have already tried a lot of the settings in AM
ptions under AM;standards.
I am using the latest version of MDT (2009)
Thanks for any tips
Thanks for any tips
Options
- Highlight
- Email to a Friend
09-22-2008 03:34 PM in reply to:
*Dupre, Joe
I still use MDT6 almost exclusively - even though I have most of the newer ones loaded. I have not experienced this problem. I set dimscale for drawings like the old days, 1/4 scale plots I draw things 1/1, make the insertion of the drafting format 4 times bigger, set dimscale to 4 and plot at 1/4. I do this in both model space and paper space, without ever seeing the forced setting you describe. Maybe you have something set in your dwt to change it to 1.
Options
- Highlight
- Email to a Friend
09-23-2008 08:54 PM in reply to:
*Dupre, Joe
Yes you are probably right about some setting... But where to find it? Any suggestions?
Options
- Highlight
- Email to a Friend
*Dupre, Joe
Options
- Highlight
- Email to a Friend
*Dupre, Joe
Options
- Highlight
- Email to a Friend
09-23-2008 09:37 PM in reply to:
*Dupre, Joe
Sorry for the triple reply, still getting used to the new forum interface. hehe
I keep getting an Error message after posting a reply, but message does get displayed apparently...
Interface looks a lot better by the way!!
Options
- Highlight
- Email to a Friend
11-06-2009 11:14 PM in reply to:
*Dupre, Joe
Did you ever get a fix? I have the same issue in MDT 2009
