• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Mechanical Desktop
    Active Member
    zdanovich
    VBA - MDT 6 Error cteating a Mate constraint
    297 Views, 0 Replies
    02-09-2011 01:21 AM
    I have a problem. I want to create a Mate constraint between WorkPlane and McadPoint. I wrote this code:
    Dim Patty As McadComponent
    Set Patty=mcad.ActiveDocument.AssemblyMgr.RootDefinition.Children(0)
    Dim Wplane As McadPlane, wpFeat As McadFeature,anyWP As McadPlane
    For Each anyWP In Patty.definition.body.WorkPlanes
    For Each wpFeat In anyWP.GetFeatures
    If wpFeat.name Like "*Base#*" Or wpFeat.name Like "*base#*" Then
    Set Wplane = anyWP: GoTo exF
    End If
    Next
    Next
    exF:
    Dim pt As McadPoint
    Dim utM As McadUtility
    Set ut = ThisDrawing.Application.GetInterfaceObject("mcad.Application").ActiveDocument.Utility
    Dim Val As McadValue: Set Val = ut.CreateValue
    ' CODE '
    Dim C2 As IMcadGeometry: Set C2 = Wplane
    Dim dM1 As McadConstraintDescriptor: Set dM1 = ut.CreateConstraintDescriptor(mcCompMate)
    dM1.Operand1 = pt: dM1.Operand1Orientation = mcRaw: dM1.Operand2 = C2: dM1.Operand2Orientation = mcRaw
    dM1.Value = Val
    Dim M1 As McadComponentConstraint: Set M1 = kt.AddConstraint(dM1)
    When I try to create a new constraint I get an error: -2147196502(800461aa) "Generic Failure to executo operation with provide arguments". I have to select WorkPlane without Pick.
    Please, help me!
    Thanks!
    Please use plain text.
