IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Unable to install content libraries for Autocad Mech 2010 64-bit on Windows 7
Having an issue installing the concent libraries for Autocad Mechanical on a 64-bit Windows 7 machine.  During the install it give me this error (Error 1320. The specified path is too long: c:\documents and settings\all users).  If I go into configure the installation to modify the Content libraries under Autocad Mechanical 2010, it gives me this error (C:\Documents and Settings\All Users\Documents\Autodesk\ACADM 2010\ACADM\Gef\Gdb).  Any ideas?
Tammy
RogerMollon
Tammy,
Since this Mechanical Desktop (MDT) Forum is not for AutoCAD Mechanical, I suggest that you post in the AutoCAD Mechanical Forum:
http://forums.autodesk.com/t5/AutoCAD-Mechanical/bd-p/39
or possibly better the Installation and Licensing Forum where the install experts hang out:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
I hope this helps,
Roger Mollon
Forge - Strategic Tech Consultant - Novi
Autodesk, Inc. - Retired
Sridhar-Autodesk
Hi, Tammy
The default install location for content libraries on a Vista or Windows 7 OS machine is as follows
C:\Users\Public\Documents\Autodesk\ACADM 2010\ACADM\Gef\Gdb
Can you try the above path during installation and verify if it works?
Please find attached snapshot.
Sridhar Subramani
Senior Product Owner
This problem is no longer a considered because it has been solved.There is away to fix this problem and the name of that software is Long Path Tool.I highly recommend it to you since I have already used it.
