• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Mechanical Desktop
    Member
    Accepted Solution
    Unable to install content libraries for Autocad Mech 2010 64-bit on Windows 7
    960 Views, 3 Replies
    05-18-2011 11:39 AM
    Having an issue installing the concent libraries for Autocad Mechanical on a 64-bit Windows 7 machine.  During the install it give me this error (Error 1320. The specified path is too long: c:\documents and settings\all users).  If I go into configure the installation to modify the Content libraries under Autocad Mechanical 2010, it gives me this error (C:\Documents and Settings\All Users\Documents\Autodesk\ACADM 2010\ACADM\Gef\Gdb).  Any ideas?
    Tammy
    Please use plain text.
    Employee
    Re: Unable to install content libraries for Autocad Mech 2010 64-bit on Windows
    05-18-2011 05:02 PM in reply to: tforal
    Tammy,
    Since this Mechanical Desktop (MDT) Forum is not for AutoCAD Mechanical, I suggest that you post in the AutoCAD Mechanical Forum:
    http://forums.autodesk.com/t5/AutoCAD-Mechanical/bd-p/39
    or possibly better the Installation and Licensing Forum where the install experts hang out:
    http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
    I hope this helps,
    Roger Mollon
    Director, Components Engineering
    Design, Lifecycle, & Simulation Product Group
    Autodesk, Inc.
    Employee
    05-18-2011 07:45 PM in reply to: tforal
    Hi, Tammy
    The default install location for content libraries on a Vista or Windows 7 OS machine is as follows
    C:\Users\Public\Documents\Autodesk\ACADM 2010\ACADM\Gef\Gdb
    Can you try the above path during installation and verify if it works?
    Please find attached snapshot.
    Sridhar Subramani
    Autodesk, Inc.
    New Member
    02-07-2013 06:37 AM in reply to: Sridhar-Autodesk
    This problem is no longer a considered because it has been solved.There is away to fix this problem and the name of that software is Long Path Tool.I highly recommend it to you since I have already used it.
