IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
The files of Inventor 2009 can not be saved to old version style, such as 2005?
I have some important files of Inventor 2009 that I cannot save to old version style to my friends. Does Autodesk company offer transferring program to solve this version problem?
Sincerely,
John
RogerMollon
The best approach is to export your 2009 model to the STEP format and then have the others import that file into 2005.  You'll end up with everything in 2005 except for the feature recipe and assembly constraints.
Inventor, like all other parametric, feature based models, don't support saving back to older versions because the newer version contains feature definitions and such that the old version doesn't support.
I hope this helps,
Roger Mollon
Forge - Strategic Tech Consultant - Novi
Autodesk, Inc. - Retired
Thanks a lot.
