• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Mechanical Desktop
    Accepted Solution
    On-screen commands
    633 Views, 8 Replies
    01-03-2013 02:40 AM
    When I start typing a command, options appear in the command window where previously they would appear on-screen. How can I get the commands to appear on-screen once again?
    Please use plain text.
    Employee
    Re: On-screen commands
    01-03-2013 09:10 AM in reply to: tmccar
    Set CMDDIA=1 and FILEDIA=1.
    Roger Mollon
    Director, Components Engineering
    Design, Lifecycle, & Simulation Product Group
    Autodesk, Inc.
    01-04-2013 12:52 AM in reply to: rogermollon
    They are both set to 1 at the moment
    Distinguished Mentor
    ampster
    01-04-2013 05:52 AM in reply to: tmccar
    are you by chance talking of the "feature" where when you start to type a command, the text of what you are typing appears on both the command line and on screen, next to your cursor?
    If so, same situation here, I no longer see the text appearing next to my cursor.
    01-04-2013 06:18 AM in reply to: ampster
    Yes- I recall one command, in Plant 3D ("Plantpartconvert") where the options for adding a port would appear stacked beside the cursor, and you could click on the required one. Now they are on the command line.
    ampster
    01-04-2013 07:41 AM in reply to: tmccar
    cmddia and filedia, both set to 1 has to do with commands showing a pop-up window to adjust command parameters.  I don't believe either of those variables have anything to do with this text on screen "feature".
    I'm at a loss on this also, used to work for me and now it doesn't.  I cannot find anything under options so suspect it's a variable not listed in options.
    01-04-2013 10:20 AM in reply to: ampster
    I don't know. It was working fine until one of the IT people said I needed an upgrade of Plant 3D. After this was complete, it disappeared.
    ampster
    01-04-2013 10:40 AM in reply to: tmccar
    Does Mech Desktop have a variable named "dynmode"?
    That appears to affect this situation in plain Acad, mine was set to -3.  After changing it to 3, commands appeared next to my cursor, however I prefer to disable dyn input so I'll have to play around with the different options to see what works.
    01-11-2013 09:24 AM in reply to: ampster
    That's it - you have solved it, thanks
