Autodesk Mechanical Desktop
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
My VC++ applicatio n which works with MDT2004 does not work with MDT2007
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
131 Views, 2 Replies
11-22-2007 10:36 PM
I have developed a VC++ application which converts the Mechanical desktop files into Step/DXF files. The application works fine with MDT2004 but has been broken when trying to work with MDT2007.
The problem is the call to the function CoCreateInstance fails with hr = NOINTERFACE for the code snippet mentioned below:
AutoCAD::IAcadApplication* AcadApp=NULL;
CLSID clsID;
CLSIDFromProgID(L"AutoCAD.Application.16", &clsID);
hr = CoCreateInstance(clsID, NULL, CLSCTX_LOCAL_SERVER, __uuidof(AutoCAD::IAcadApplication), reinterpret_cast(&AcadApp));
if(!AcadApp)
//Failed to create MDT object so could not proceed.
//returning with failure
hr = E_FAIL;
I have tried the following to resolve the problem.
1) I used the CLSID i.e. "AutoCAD.Application.17" for MDT2007 and build the application using the MDT2007 acax17enu.tlb. The application worked with MDT2007, but fails to work with MDT2004 (even after using appropriate CLSID "AutoCAD.Application.16").
2) Calling CoCreateInstance twice i.e. Call for MDT2007(using its CLSID and hardcoded IAcadApplication interface id) and if it failed then Call for MDT2004(using its CLSID and hardcoded IAcadApplication interface id). But the application gives a runtime "COM Surrogate Error" message.
I want the same application to work with both MDT2004 and MDT 2007. Please help me or provide me information regarding how to resolve this problem.
Thanks in Advance.
CLSID clsID;
if(!AcadApp)
hr = E_FAIL;
Thanks in Advance.
*Kar Poh Tay \(Autodesk\)
Re: My VC++ applicatio n which works with MDT2004 does not work with MDT2007
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-25-2007 06:10 PM in reply to:
SunShine
You can try to get IAcadApplication using the following way:
AutoCAD::IAcadApplication *pAcad;
HRESULT hr = NOERROR;
LPDISPATCH pAcadDisp = acedGetIDispatch(TRUE);
if(pAcadDisp==NULL)
return;
hr = pAcadDisp->QueryInterface(AutoCAD::IID_IAcadApplic ation,
(void**)&pAcad);
pAcadDisp->Release();
if (FAILED(hr))
return;
However as the tlb is different in MDT2004 ("acax16enu.tlb") and MDT2007
("acax17enu.tlb"), you will need to import and build with the respective tlb
for MDT2004 and MDT2007.
Kar Poh
Software Engineer
Manufacturing Solutions Division
wrote in message news:5784230@discussion.autodesk.com...
CLSID clsID;
if(!AcadApp)
hr = E_FAIL;
Thanks in Advance.
if(pAcadDisp==NULL)
return;
(void**)&pAcad);
if (FAILED(hr))
return;
Kar Poh
Software Engineer
CLSID clsID;
if(!AcadApp)
hr = E_FAIL;
Thanks in Advance.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-28-2007 12:23 AM in reply to:
SunShine
Can you tell me, where did you find this application. We spend a lot of time
to do DXF and STEP.
to do DXF and STEP.
