• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Mechanical Desktop
    *Chas
    Re: MDT vs Inventor
    07-06-2006 11:26 AM in reply to: *MikeF
    I don't have an issue keeping track of the files and folders but it seems IV
    does have an issue, that's my point.
    Chas
    wrote in message news:5226026@discussion.autodesk.com...
    >There's always the pressure to convert to Inventor. I've looked at the
    >Inventor newsgroup and there are some unhappy campers with Inventor.
    Why don't you post this question over there?
    That is where the people who have succumbed to the pressure to convert hang
    out. You might get some input from their experience in making the
    transition, here you are limited to those who couldn't make the transition.
    I used to tell my class first day that MDT was my preferred CAD program
    until I fully understood Inventor.
    Inventor Plus
    No need to profile sketches
    Shared sketches
    Derived sketches
    Derived parts
    Far easier parametric work-plane creation (I ran into a lot of MDT users who
    use ACAD UCS command to create non-parametric sketchplanes/workplanes).
    Parametric surface creation
    Sculpt tool that doesn't exist in MDT
    Boundary Patch tool that doesn't exist in MDT (tangent)
    Loft options that don't exist in MDT
    Sweep options that don't exist in MDT
    Fillet options that don't exist in MDT
    Interactive assembly constraints that don't exist in MDT (I ran into a lot
    of people who use ACAD align command instead of parametric 3D constraints
    which they didn't understand how to use).
    Assembly motions that don't exist in MDT
    Sheet metal flat pattern generation with bend allowance
    Construction Environment tools for fixing imported geometry (MDT used to
    lead in this function - no longer true).
    Frame generator tools that don't exist in MDT
    Inventor Studio
    DWF Animation
    Assembly save as stl
    Creating traditional 2D drawings from 3D models or assemblies is far easier
    all the way around.
    I don't understand what all the difficulty is that long time MDT users have
    with part, assembly and drawing files being separate files. What is the
    difference between a file and a folder in terms of management? In the
    digital world a file or a folder of files is all 1s and 0s. Actually in the
    physical world a part is a part, an assembly is a group of parts, a drawing
    is a flat sheet of paper, not a part or an assembly. Wow that is confusing
    to keep track of. (I often saw MDT users always start with an assembly file
    rather than a part file and they didn't know how to use the assembly
    Catalog).
    >I can build solids with MDT. So, why would one change over?
    That is great! Your CAD software purchases are over as MDT is no longer
    sold anyhow. Be happy you don't have to keep up with learning all of the
    above and the inevitable pains with new technology. Just hope your
    employment is secure clear to retirement. (Same thing I said to board
    drafters 20 years ago.)
    Please use plain text.
    Re: MDT vs Inventor
    07-06-2006 01:33 PM in reply to: *MikeF
    Hi Phil,
    I notice in your signiture that you are a gauge designer at North American Lighting. That is why you understand where I'm coming from, as we are gauge and fixture builders too. There is a tremendous amount of surface manipulation required in fixture building, as well as the need for points and lines (SPC points and vectors). Really, for our line of work, a hybrid modeller, such as Mechanical Desktop, is essential. This is where most modern "Solid Modeler" fall short. Surfacing is not dead, nor will it ever be.
    Dan
    *Phil Kenewell
    Re: MDT vs Inventor
    07-06-2006 02:12 PM in reply to: *MikeF
    Dan,
    Yes - Your absolutely correct. I design gauges and test fixtures for
    automotive lighting. If you think of a modern automotive Headlamp for
    example, you can see where were coming from. Lots of free-form surfacing
    involved, and always the need to express SPC points in terms of unit vectors
    (I,J,K). On gauges, we have to create functional pin check rails that match
    the nominal gap and flushness between the car body and the lamp. Not to
    mention the environmental fixtures, where we have to simulate the entire
    surrounding.
    Thanks for the reply.
    Phil Kenewell
    Gage Designer
    North American Lighting, Inc.
    Re: MDT vs Inventor
    07-07-2006 02:27 AM in reply to: *MikeF
    Hi Phil,
    We do those types of fixtures quite often. In fact, we have built fixtures for your company.
    Dan Message was edited by: DBayn
    *Phil Kenewell
    Re: MDT vs Inventor
    07-07-2006 05:17 AM in reply to: *MikeF
    Interesting - What's the name of your company?
    Phil Kenewell
    Gage Designer
    Re: MDT vs Inventor
    07-07-2006 05:36 AM in reply to: *MikeF
    A.V. Gauge and Fixture Inc.
    *Phil Kenewell
    Re: MDT vs Inventor
    07-07-2006 06:29 AM in reply to: *MikeF
    Ah Yes - I've seen a couple of gauges down at the Illinois plant with your
    logo on them. You guys are in Ontario Canada - right? Our internal gauge and
    fixture department is located at the Farmington Hills tech center in
    Michigan.
    Phil Kenewell
    Gage Designer
    Re: MDT vs Inventor
    07-07-2006 07:08 AM in reply to: *MikeF
    Yes, just outside Windsor.
    Distinguished Contributor
    Re: MDT vs Inventor
    07-08-2006 09:41 AM in reply to: *MikeF
    "No need to profile sketches", kind of correct but to do anything with a sketch, you still have to click on the Return Icon...sounds like the same thing as profiling a sketch to me. same clicks...
    "Far easier parametric work-plane creation (I ran into a lot of MDT users who use ACAD UCS command to create non-parametric sketchplanes/workplanes)." True and False, sounds like the instructor didn't properly show them how to create work planes.
    "Fillet options that don't exist in MDT" MDT can do Fillets that IV cannot, I learned this in a IV class recently, and can show proof.
    "Interactive assembly constraints that don't exist in MDT (I ran into a lot of people who use ACAD align command instead of parametric 3D constraints which they didn't understand how to use)." 3D constraints in MDT are far superior, you do NOT have to create a midplane workplane on the first part to mate it with the "midplane" of another part, IV you must and it must be visible and it must be a month that ends in Y and a new moon...etc
    "Inventor Studio" Oh yes, I love the great "Friday Pictures" Spongebob with a light saber and all, how long has render been around? How about a useable drawing to make parts!?!
    One question I have, why does it take soooo long to insert a simple socket head cap screw in IV, if you can even get it to work? 2-3 minutes is out of the question. Especially when you have to insert 1-300 screws...
    So no pressure here...I have my full list of comparison at work and will try to post it at a later time.
    *Robert Davis
    Re: MDT vs Inventor
    07-10-2006 11:59 AM in reply to: *MikeF
    JD typed... "Why don't you post this question over there?
    until I fully understood Inventor."
    Yeah. Take a look over there and see my questions on why half the *&^%
    advertised in IV doesn't work or is broken /fixed from release to release
    and unreliable. Be sure and read my rants and responses showing how
    disappointed I am with IV. They are from a LONG time MDT user that is
    trying to understand why on the 11th release of IV that the software is
    totally unstable and not a time saver at all for me. Also, be sure and keep
    in mind that JD is a tool and has an agenda that doesn't match yours, as he
    makes money "teaching" people how to use a program that is so "intuitive".
    Give it a *&^%$# rest, JD. I've been to the "promised land" and it's under
    construction. Here's your new icon.
    Robert Davis
    QC/CMM Dept.
    robert@easmfg.com
    E.A.S. Manufacturing Co., Inc.
    804 Via Alondra
    Camarillo, Ca 93012
    805-987-3665 Voice
    805-987-7948 Fax
    eas@easmfg.com - General E-Mail
    www.easmfg.com - Web Site
    Inventor Plus
    Shared sketches
    Derived sketches
    Derived parts
    Inventor Studio
    DWF Animation
    all the way around.
    Catalog).
