• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Mechanical Desktop
    Distinguished Contributor
    MDT 2009 File Migration Utility
    1104 Views, 4 Replies
    12-16-2011 06:44 AM
    Trying to use the MDT migration utility and it fails everytime right after the continue selection on the Backup dialog:
    Right-clicking on dwgmigr13.exe directly and picking Run as Administrator has the same result.  I just looked at the dwgmigr.txt file in the same folder (C:\Program Files\Autodesk\MDT 2009\Desktop\Migration) and it has this sentence:
    "You must first run the Autodesk Mechanical Desktop 2008 Basic before running the File mIgration utility."
    Is that the problem, or is the utility failure a 64-bit issue?  Also: Running MDT 2009 Basic made no difference either.  My MDT 2009 is at SP3.
    KState92
    Inventor Series 2010 SR SP4
    Windows 7 64 bit - SP1
    8 GB Ram
    Quadro 2000
    Please use plain text.
    Employee
    Re: MDT 2009 File Migration Utility
    12-26-2011 05:41 PM in reply to: kstate92
    KState92,
    I see it's been 10 days with no reply, so even though I can't be much help I'll sugggest 2 things:
    1) You might try starting MDT and then leave it running minimized on the taskbar while you try the file migration utility, I think I recall that working for some people in the past,
    2) You should re-post this message over in the Inventor Discussion Group, there are folks over there that can help and I doubt any of them check this discussion group anymore.:
    http://forums.autodesk.com/t5/Autodesk-Inventor/bd-p/78
    I hope this helps,
    Roger Mollon
    Director, Components Engineering
    Design, Lifecycle, & Simulation Product Group
    Autodesk, Inc.
    01-03-2012 05:50 AM in reply to: rogermollon
    Option 1 made no difference.  Could you please tell me if the utility dwgmigr13.exe will even run in Windows 7 64 bit?
    KState92
    8 GB Ram
    Quadro 2000
    05-07-2012 11:52 AM in reply to: kstate92
    This thread appears to be dead, but in case anyone runs into this issue a solution that should work is to run the migration utility as an administrator.
    Right Click on the utility and select Run as Administrator.
    or
    Right Click on the utility and select Properties
    Then select the Compatibility tab and check "Run this program as an administrator".
    Sailin Benedum
    05-07-2012 11:56 AM in reply to: sbenedum
    I did try that (as I mentioned in my first post) and it made no difference.  Though I'm glad it worked for you.
    or
    KState92
    8 GB Ram
    Quadro 2000
