• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Mechanical Desktop
    Active Member
    MD'09 didn't show the window dialog box while use "open" command
    746 Views, 3 Replies
    03-16-2011 08:15 PM
    dear all,
    i got some unusuall error & i can't fix it till now unless i reinstall the software. it's annoying me so much
    some command like "open" , "amfillet" , "amextrude" , etc then it's shown the window dialog box (see attachment "normal.jpg").
    but in this case, it won't show the window dialog box (see attachment "error.jpg").
    is there an options that i should be checked?
    do you all understand about what i mean? (cuz, i'm not good in english conversation & i still confused how to explain this error). i'm waiting for your help
    thanx,
    Noel
    Please use plain text.
    Employee
    Re: MD'09 didn't show the window dialog box while use "open" command
    03-17-2011 04:33 PM in reply to: noel20
    You need to set 2 sysvars, look up FILEDIA and CMDDIA in the Help system.  I can't say why they are getting set to 0 (zero), but you want them set to 1 (one).  On the command line enter "FILEDIA" then enter, at the prompt enter "1".  Do the same with "CMDDIA".
    When you can, note when the dialogs go away again to figure out who's changing these system settings.
    I hope this helps.
    Roger Mollon
    Director, Components Engineering
    Design, Lifecycle, & Simulation Product Group
    Active Member
    03-18-2011 07:25 PM in reply to: noel20
    dear roger mollon,
    thanx for the solution. i thought it always should be reinstall to fix the problem (repair the installation can't fix it)
    i hope there's someone can explain what was my mistake that unconsciously make it set to "0" without any notification. or, is there some commands to lock the sysvar, so whatever happened it can't be changed without open the lock .but  ... once again i say thank you very much. :smileyvery-happy:
    God bless u
    Active Contributor
    iErdogan
    10-15-2011 04:48 PM in reply to: noel20
    Dear Roger Mollon,
    Thank you for all, it was a problem for me too
    All commands working with window in right click wasn't working,
    Thanks from Turkiye, I'll try immediately.
    _________________________________________
    .:Erdogan I:.
    Autodesk inventor Design Suite Premium 2012
    Windows 7 x64, 750 GB harddisk
    Intel core i5 Cpu @3.2 GHz, 8 GB Ram,
    nVidia Quadro 2000 D Graphics Card
    http://ierdogan.tr.gg
    Paylaşmak Güzeldir.(in Turkish)
    Sharing is beautiful.(in English)
