• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Mechanical Desktop
    *Dupre, Joe
    How to convert MDT part to Acad wireframe or solid?
    25 Views, 5 Replies
    12-07-2001 05:24 AM
    I need to convert some MDT parts and assemblies into 3D solids or wireframes
    that can be opened or imported by generic Autocad. Is this possible? If I
    just do a Save As DXF the parts are not visible in vanilla Autocad. I tried
    exploding a part and that doesn't work either.
    - Joe
    Please use plain text.
    *Rory
    Re: How to convert MDT part to Acad wireframe or solid?
    12-07-2001 05:30 AM in reply to: *Dupre, Joe
    Easiest way is to do AMACISOUT on the part, which will create an ACIS
    (*.sat) file.
    Then ACISIN into AutoCAD!.
    Only thing you might need to check is the ACISOUTVER system variable as
    AutoCAD can only read earlier versions of acis, whereas MDT can export later
    ones (and also earlier compatible ones if configured correctly)
    Rory
    "Joe Dupre" wrote in message
    news:0639F179257E6FB0905C0E28E0CAE36A@in.WebX.maYIadrTaRb...
    wireframes
    I
    tried
    > - Joe
    *Hatziemmanuel, Alex
    12-07-2001 05:31 AM in reply to: *Dupre, Joe
    Install the object enabler that will allow Autocad to open a MDT file...go
    here for more info
    http://pointa.autodesk.com/local/enu/portal/nav/indexPage.jsp?field=4&page=n
    av/nav_frame.jsp%3Fmenu=productive_menu%26ind=gd%26file=/local/enu/portal/pr
    odcent/obj_enabler.htm
    wireframes
    I
    tried
    > - Joe
    12-07-2001 05:43 AM in reply to: *Dupre, Joe
    Sorry, try this link http://support.autodesk.com/getDoc.asp?id=TS63958
    wireframes
    I
    tried
    > - Joe
    *Keller, Kent
    12-07-2001 05:49 AM in reply to: *Dupre, Joe
    If you want wireframes, then load exp2wire.arx and run exp2wire
    if you want the solid then use amacisout
    Kent
    > - Joe
    Distinguished Contributor
    Re:
    12-07-2001 07:50 AM in reply to: *Dupre, Joe
    Joe,
    I don't recall seeing what version of plain jane AUTOCAD you are trying to export too.
    Would make a difference in the answer you would get here.
