• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Mechanical Desktop
    *Dupre, Joe
    How to add reference dim to invisible construction line?
    29 Views, 9 Replies
    09-20-2001 04:02 AM
    How do I add an ordinal reference dim to a construction line that was used
    when creating a feature?
    For example, when creating a rectangular cutout in a panel I want to
    dimension the "center" of the cutout, not the edges. I can do this with
    construction lines when creating the sketch for the rectangular feature, but
    the construction lines are obviously gone in the drawing view.
    Is there any way to attach an arbitrary dimensionable reference point to a
    feature? Any work-arounds?
    - Joe
    Please use plain text.
    *Keller, Kent
    Re: How to add reference dim to invisible construction line?
    09-20-2001 04:21 AM in reply to: *Dupre, Joe
    If you recreate the construction line in paperspace and annotate it you can dimension to
    it. Some people make a small hole or notch at the middle of the feature to be able to
    dimension off it. Or of course you can make the pardims visible in paperspace
    Kent
    "Joe Dupre" wrote in message
    news:0574B5EADE4E2C76AB9ADB2EC466B4C6@in.WebX.maYIadrTaRb...
    > Thanks,
    > - Joe
    *Keller, Kent
    Re:
    09-20-2001 04:30 AM in reply to: *Dupre, Joe
    Actually I forgot, you can use mid snaps on amautodims now. run amautodim, choose
    ordinate (I think that is what you mean?) and choose all the features except the 0.0
    location. then use mid snap to place the 0.0
    Kent
    > > Thanks,
    > > - Joe
    *Dupre, Joe
    Re:
    09-20-2001 05:06 AM in reply to: *Dupre, Joe
    "Kent Keller" wrote in message
    news:7E343A4EE85202508E6BC5F208DFEFA4@in.WebX.maYIadrTaRb...
    amautodim, choose
    except the 0.0
    Can you expand on this? I don't see quite how to do this (what objects to
    pick and why). There isn't much documentation on AMAUTODIM that I could
    find.
    I don't know what this will look like once transmitted, but I have attempted
    to create some ASCII art to show what I am attempting. Below shows a corner
    of a panel, with an obround hole near the edge. How can I create a
    horizontal ordinal dimension with the upper right corner being reference
    (0.00), and dimensioning to the midpoint of the top of the obround? (Or
    ideally the point that is midway between the two arcs, shown by the + in the
    drawing.)
    - Joe
    ______________
    _________ |
    (____+____) |
    *Krech, Brad
    Re:
    09-20-2001 05:07 AM in reply to: *Dupre, Joe
    If your trying to dimension to the center of a slot, the true center of the
    slot that is, what I usually do is place a workpoint then sketch around that
    workpoint and extrude the slot as a whole.
    Then when you create views the parametric dimensions will appear.
    Otherwise I use just regular Autocad linear dimensions and annotate them.
    Good luck!
    news:EFC6F84F1A4759BE405293C7BFC2331B@in.WebX.maYIadrTaRb...
    > amautodim, choose
    > except the 0.0
    > find.
    attempted
    corner
    the
    > drawing.)
    > - Joe
    > ______________
    > _________ |
    > (____+____) |
    *Keller, Kent
    Re:
    09-20-2001 05:59 AM in reply to: *Dupre, Joe
    Joe
    If you want the true Center, then try addins some small line or circle to the drawing view
    as a annotation at the true center, and dimensioning to that. If the edge works for you
    see the avi file I posted in customer fils
    Kent
    > amautodim, choose
    > except the 0.0
    > find.
    > drawing.)
    > - Joe
    > ______________
    > _________ |
    > (____+____) |
    *Dupre, Joe
    Re:
    09-20-2001 08:05 AM in reply to: *Dupre, Joe
    Thanks Kent,
    Where are the customer files? Is this a FTP site?
    -Joe
    news:179ECD8B5CD416195B7B65FBA4CAF4E7@in.WebX.maYIadrTaRb...
    > Joe
    the drawing view
    works for you
    > Kent
    > > amautodim, choose
    > > except the 0.0
    to
    > > find.
    attempted
    corner
    the
    > > drawing.)
    > > - Joe
    > > ______________
    > > _________ |
    > > (____+____) |
    *Brown, Anne
    Re:
    09-20-2001 08:54 AM in reply to: *Dupre, Joe
    Joe -
    Customer Files is a discussion group for upload of problem files
    for review. Please Zip any files prior to uploading to conserve
    user download time and server space.
    For NNTP newsgroup readers the Customer-files newsgroup can be
    found at
    news://discussion.autodesk.com/autodesk.autocad.customer-files.
    You may also access the customer-files group via the HTTP
    web-based forums at
    http://discussion.autodesk.com/WebX?14@@.ee940b5.
    Anne Brown
    Manager, Moderator
    Autodesk Product Support discussion groups
    Discussion Q&A: http://www.autodesk.com/discussion
    Joe Dupre wrote:
    > Thanks Kent,
    *Russell, David
    09-20-2001 10:30 PM in reply to: *Dupre, Joe
    When I want to dim to the center of a cutout, I add a centerline, the refdim
    to the centerline. Is this what you might be looking for?
    David Russell
    QED, Inc.
    750 Enterprise Dr.
    Lexington, Ky. 40510
    ph. 859-231-0338
    fx. 895-231-0376
    e: jdr407@kih.net
    but
    > Thanks,
    > - Joe
    Outgoing mail is certified Virus Free.
    Checked by AVG anti-virus system (http://www.grisoft.com).
    Version: 6.0.280 / Virus Database: 147 - Release Date: 9/11/2001
    *Keller, Kent
    Re:
    09-21-2001 01:27 AM in reply to: *Dupre, Joe
    Duhhh absolutely better than my suggestion of annotations. Boy this brain of mine is
    due for a good flushing, it is getting a little gummed up I think
    Kent
    "David Russell" wrote in message
    news:B61B3038D4D772B14DFE17D79AD614F7@in.WebX.maYIadrTaRb...
