• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Mechanical Desktop
    Active Contributor
    Dumb question....Unigraphics "reference sets"???
    1465 Views, 7 Replies
    04-16-2002 09:57 PM
    A few years ago I worked for a company who used Unigraphics....anyone familiar with this software? With Unigraphics you could set up "reference sets".... Within an assembly drawing, one could select a part or group of parts as as "set" (for instance, the rear section of a car frame) ....this set could be brought into an upper assembly,(for example, axle installation) eliminating the need to load more parts than needed ( say, the entire car frame). Multiple reference sets could be set up,(example...rear frame, front frame, mid frame...etc) allowing different upper assembly drawings to show different parts of the same assembly without having to load the entire assembly. Does what I have said make sense to you? If any of you have used Unigraphics, I am sure it does. Is there any way to do this in MDT?
    Mike
    michaelbrainard@hotmail.com
    Please use plain text.
    *Dyson, Ray
    Re: Dumb question....Unigraphics "reference sets"???
    04-16-2002 10:19 PM in reply to: michaelbrainard
    Mike,
    I've never actually used Unigraphics, but don't
    subassemblies do the same?
    Ray
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    A
    Mike
    Active Contributor
    Re:
    04-16-2002 10:27 PM in reply to: michaelbrainard
    Yes and no.....for example....you are showing the installation of a small item....maybe a fuel filter...mounted under the frame of your car....you only need to show the left frame rail to show the location of the filter. One reference set inside the "frame" assembly would be called "frame rail - filter location" or whatever you wanted to call it. When you insert the frame assembly you would select the reference set you want in your upper assembly. One argument to this might be to only insert the frame rail.....not the entire frame. True...but depending on the assembly structure, this would FUBAR the bill of materials...because the filter is bolted to the "Frame upper assembly"....not just the frame rail. Or you may need to show multiple parts of an assembly to reference the location of the filter...say the frame rail and a cross member..... Make a bit of sense at all? I think it is Monday again......
    *Dyson, Ray
    Re:
    04-16-2002 10:44 PM in reply to: michaelbrainard
    Never tried it with MDT parts, but you might look at the
    group command. It's an AutoCAD command but might work for you.
    Ray
    Yes
    again......
    *Laimer, Leo
    04-17-2002 01:31 AM in reply to: michaelbrainard
    Mike,
    There is NO such feature in MDT6 and none in IV
    either. This is one of the biggest shortcomings in the two packages
    IMHO.
    The only workaround that come in mind
    are:
    - make heavy use of a clever subassembly
    structure
    - in MDT, perform xref/unload on subassemblies you
    don't need at the moment
    Both methods are far from the power of reference
    sets (or configurations as named by others...)
    Leo Laimer
    Maschinen-
    und Fertigungstechnik
    A-4820 Bad Ischl - Austria
    style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
    A
    Mike
    *Sense\, CAD
    Re:
    04-17-2002 11:17 AM in reply to: michaelbrainard
    structure
    MDT's restructure command is a godsend for this.
    Pity Inventor still sucks at the same thing...
    Mike,
    IMHO.
    are:
    structure
    you don't need at the moment
    Leo
    Laimer
    Maschinen- und Fertigungstechnik
    A
    Mike
    Distinguished Contributor
    Re:
    04-18-2002 08:29 PM in reply to: michaelbrainard
    ok i might not of read this properly but wont scenes do what you want? create a scene and the make different parts visible? im probably wrong.... usually am ;-)
    New Member
    omucudisku
    01-09-2011 12:33 PM in reply to: michaelbrainard
    I hope somebody will reply after 9 years :smileyhappy:)
    I have a Dumb question to your Dumb question: What are the reference sets in UG NX, I work at a project in UG NX Electrical Routing and I am stuck, I dont know how to work with refernce sets, what they are and what they do.
