• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Mechanical Desktop
    Distinguished Contributor
    2007 File Migration Utility doesn't seem to work
    526 Views, 1 Replies
    05-21-2010 11:12 AM
    I can start the utility, provide it with a list of files, set it to analyze and click run. A dialog box instantly pops up and states Windows cannot find 'acad.exe'. I've ran MDT 2007 and even the Basic version first before running the utility with no different result. And leaving MDT open, the Utility tells me to close MDT first. MDT is part of Inventor Series 11, in case that's a factor. Is there a custom startup switch I need to add to a short cut? Any ideas at all?
    XP SP 32bit
    Inventor 11 SP4
    MDT 2007 SP2
    KState92
    Inventor Series 2010 SR SP4
    Windows 7 64 bit - SP1
    8 GB Ram
    Quadro 2000
    Please use plain text.
    Active Contributor
    Re: 2007 File Migration Utility doesn't seem to work
    11-11-2010 04:15 AM in reply to: kstate92
    i have mdt2009 and the file migration utility dont work, only the file migration utily for mechanical work
