• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide
    New Member
    asliev
    failed to check out a license with AdLM code: 20
    533 Views, 2 Replies
    08-04-2011 09:54 PM
    Hello respected members autodesk, using a web interface topobase error "failed to check out a license with AdLM code: 20." The problem is this: a user1 has gone web interfase, but user2 can not enter, an error occurs:failed to check out a license with AdLM code: 20
    Tell me please how to configure the system so that users can logon in web interface?
    Thanks!
    Please use plain text.
    TravisNave
    Re: failed to check out a license with AdLM code: 20
    08-09-2011 10:29 AM in reply to: asliev
    Definitely a strange one.
    Have you tried these examples?
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13894457&linkID=9242778
    Or service pack updates?
    http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9242779#section1
    For faster responses concerning Autodesk licensing issues, please post your questions in the Installation and Network Licensing user forum here:
    http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    New Member
    asliev
    08-09-2011 10:50 PM in reply to: TravisNave
    Thank you for your reply, unfortunately your answer did not help us, we do not have the server file CascadeInfo.cas most likely this is due to licenses on the server, we have the settings you can use only one license, but no such license web properties Requests from the same user/ host do not consume a new license.
