• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide
    Active Member
    error with extension join with oracle database
    22 Views, 0 Replies
    02-13-2008 02:01 AM
    we are trying to extend the map database with oracle using feature join. The join is on the string type column on map and char(20) on Oracle table.
    There is no error in join, but after selection of joined extension in the " layer " edit wizard, error(you're about to change to an incompatible data resource) is raised as shown in attachment and the map contents in the viewer are vanished.
    any help in this regard is greatly appreciated
    Please use plain text.
