• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide
    Distinguished Contributor
    connecting to an access database (mapserver 2013)
    1039 Views, 3 Replies
    07-26-2012 10:16 AM
    I am following the exact steps in connecting to an access database
    http://wikihelp.autodesk.com/Infr._Map_Server/enu/2013/Help/0001-Getting_0/0016-Exercise16/0023-Conn...
    and I get the following error when I test connection
    An exception occurred in FDO component. RDBMS: [Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified.
    Mapserver 2013, on Windows 7/64, I have the MS access 64 drivers installed.
    any help is appreciated.
    Please use plain text.
    Re: connecting to an access database (mapserver 2013)
    07-26-2012 06:17 PM in reply to: mfernandes
    Microsoft Access Driver (*.mdb) is the 32-bit driver
    Microsoft Access Driver (*.mdb, *.accdb) is the 64-bit driver
    There should be a choice to pick between the two. It should be the second one.
    - Jackie
    07-27-2012 09:55 AM in reply to: mfernandes
    Brilliant:smileyvery-happy:
    If I can now choose between the 32bit and 64 bit drivers,
    does this mean that 64bit Map3D, Civil3D and Map server can now connect to MS office 32bit.
    or do I still need to follow the proccess as outlined here
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18307898&linkID=9240697
    to install the MS 64bit drivers.
    07-30-2012 06:54 PM in reply to: mfernandes
    Your AutoCAD variant must use the Microsoft Access driver of the same bitness.
    - Jackie
