• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide
    New Member
    cannot open coordinate system dictionaries for write
    1194 Views, 4 Replies
    08-02-2006 04:49 PM
    does anyone have any information on what causes this error. I am scratching my head here. any help will be greatly appreciated thank you so much.
    Ryan
    Please use plain text.
    New Member
    Re: cannot open coordinate system dictionaries for write
    11-02-2007 07:44 AM in reply to: mandanglo
    In your case I am not sure but in my case I got this error because I installed Civil 3d on Vista 64 bit even though it is not supported or supposed to be installed. The reason it gave me this I believe was because the corrdinate system files are stored in "C:\Program Files (x86)\Common Files\Autodesk Shared\GIS" and in the 32 bit version of windows it would go in a slightly different path. I was able to fix this by opening the drawing with a coordinate system I diddnt have on a different machine and when I added the coordinate system to civil 3d I closed the program and copied the coordinate system files over to my machine. no more error.
    New Member
    12-14-2008 06:28 PM in reply to: mandanglo
    Hi! I have just studied MAP 3D and I have this problem like that but I don't understand Unstableflame's instruction,
    please give me detail, thanks
    note : I don't know What are " add coordinate system to Civil" and "Copy coordinate system file "
    in "Copy Copy coordinate system file " , What is file??? Where is file??? and Where do I copy to Edited by: Captianbeo on Dec 15, 2008 2:59 AM
    New Member
    10-11-2009 02:02 PM in reply to: mandanglo
    You just have to open AutoCad Map or Civil as Administrator (right click on icon) and everything is going to work properly. Bye
    New Member
    06-27-2012 08:56 AM in reply to: mandanglo
    I am trying to define a coordinate system used in an african country, in both AUTOCAP MAP 2004 and AUTOCAD MAP 3D 2011,both installed in Window 7 for storing in the dictionary, for usig in several projects later. But I'm having issues.I go to Map > Tools > Define Global Coordinate System. The local projection is based on an ellipsoid. I enter all the information and select OK. I get a window saying "Cannot add coordinate system to dictionary."
    Does anyone have any idea what's going on? Thanks.
