• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide
    Active Member
    Problem ODBC Oracle on Windows 2008 64btis
    1135 Views, 3 Replies
    04-12-2012 04:48 AM
    Does anybody have an idea how to solve the problem of Infrastructure Mapserver 2013 with FDO ODBC Oracle connection?
    "An exception occurred in FDO component. Oracle ODBC Database"
    Please use plain text.
    Valued Mentor
    Re: Problem ODBC Oracle on Windows 2008 64btis
    06-16-2012 03:20 AM in reply to: ambarboza
    if your oracle database is 32 bit, you may have to install the 32 bit client on your MapGuide server
    Active Member
    06-20-2012 11:21 AM in reply to: gluckett
    I Did, but when I set on:
    IIS / Application Pools / mapserver2013 / Adivanced Settings / Enable 32-bit applications = true
    The AIMS 2013 does not work.
    Valued Mentor
    07-03-2012 07:49 AM in reply to: ambarboza
    I wouldn't set IIS to use 32bit access. FDO and IIS are really two different beasts.
    If you can't connect to ODBC on 64bit (Access) you need to download the 64bit Runtime for Access for your machine.
    http://www.microsoft.com/en-us/download/details.aspx?id=10910
    gordon
