• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide
    Valued Contributor
    Map Server2012: Application Extension component is blocked
    762 Views, 1 Replies
    04-14-2012 07:51 AM
    Hi there,
    I recently install Autodesk Infrastructure Map Server 2012, it shows Application Extension is blocked due to compatabilities issue, it ask me to install OS language package dotnetfx35langpack_64_2052.exe. But I cannot find this exe file anywhere. Any solution for this? I have both IIS and Apache server on the computer, ApacheInfrastructureWebServer2012 is automatically installed, any configuration can be done to use IIS server instead of Apache server? Thank you.
    Please use plain text.
    Employee
    konstantin.baumann
    Re: Map Server2012: Application Extension component is blocked
    04-16-2012 01:37 AM in reply to: swimming123
    I am sorry, but this is the forum for "Infrastructure Modeler" not for "Infrastructure Map Server", so it would be a good idea to ask that question here: http://forums.autodesk.com/t5/Autodesk-MapGuide/bd-p/88
