• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk MapGuide
    Member
    ManagedMC3 Error
    309 Views, 1 Replies
    02-19-2013 11:39 PM
    Hi everyone;
    I want to make a simple application about MapGuide
     string webLayout = "Library://SheBoyganPublic/WebLayouts/Test.WebLayout";
            string defaultUser = "Anonymous";
            string defaultPassword = "";
            string sessionId = "";
            protected void Page_Load(object sender, EventArgs e)
                try
                    MgUserInformation userInfo = new MgUserInformation(defaultUser, defaultPassword);
                    MgSite site = new MgSite();
                    site.Open(userInfo);
                    sessionId = site.CreateSession();
                catch (Exception ex)
                    Response.Write(ex.Message);
    I copied sample code from Setup Folder, Then I add all OsGeo dll's then published under IIS
    when I open published page I get error like following text
    My IDE Visual Studio 2010 Supports x64, AutoDesk Infrasracture Map 64 bit and IIS application pool supports 64 bit application I set to false 32 bit application compatibility from IIS, my IIs versiyon 7
    How do I run this code, My AutoDesk Infrasracture Server is Trial
    ERROR TEXT :
    'ManagedMC3' file, or the compilation or one of its dependencies. Strong name signature could not be verified. The file, or the file can be played on the delay signed but not the correct private key can be fully signed. (Exception from HRESULT is returned: 0x80131045)
    Please use plain text.
    Member
    Re: ManagedMC3 Error
    02-20-2013 01:17 AM in reply to: AliKara1
    I fixed  this error with adding InitializeWebTier method before codes
    thanks
