• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk MapGuide
    Active Member
    Flex Web Layout
    553 Views, 2 Replies
    03-06-2012 10:01 AM
    Hi Everyone,
    Does anyone know how to change the colors of the flexible web templates?  Or can you point me in the direction of a training document or example?
    Heidi
    Please use plain text.
    Re: Flex Web Layout
    03-08-2012 11:19 PM in reply to: Heidi03
    The easiest way to modify the style of the fusion template is to use a tool like Firebug or <insert developer tools of your web browser> to inspect the CSS of the element(s) in question that you want to modify. This will tell you 2 things:
     1. The CSS rules being used and their respective style settings (color, font, etc, etc)
     2. The stylesheet(s) where these rules are defined.
    Then it's a case of editing the affected CSS stylesheets to produce the look that you are after.
    - Jackie
    Active Member
    Re: Flex Web Layout
    03-09-2012 05:15 AM in reply to: jackie.ng
    Thanks Jackie... I am very new to all of this, so I will do some research and try to figure out how to do your suggestions, but thanks for pointing me in a direction!  I appriciaite it very much! Cheers
    Spoiler
    :smileyhappy:
