• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk MapGuide
    New Member
    hsmith
    ESRI .lyr files
    1075 Views, 1 Replies
    09-29-2010 02:56 PM
    Does Autodesk MapGuide support .lyr (layer) files?  If not, are there plans on adding the ability to see these services?
    Please use plain text.
    Active Contributor
    Re: ESRI .lyr files
    11-02-2010 04:28 PM in reply to: hsmith
    .lyr is not currently supported but MapGuide can import .shp, however this is not so useful for adding features with complex symbology. Under the layer properties and Themes in MapGuide, you can add a theme which will divide your layer based on a field.
