• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk MapGuide
    Valued Contributor
    nik.mazreen
    Connect to ArcSDE
    185 Views, 0 Replies
    07-28-2011 02:09 AM
    Hi..
    I’m trying to connect data from Mapguide Studio Ent. 2011 and I already follow all the steps which I should follow without success. The step as follows;
    http://gisexchange.typepad.com/blog/2010/11/adding-the-arcsde-provider-to-the-data-connect-dialog-in...
    I’m trying for a week without success and therefore, I’m seeking for your advice about this matters and hopefully can resolve this issue. The detail about the conf. as attached. Thank you.
    FYI: The ArcSDE I try to connect using  9.3.1 version 32 bit and SQL server 2008 32 bit.
    Snap From MGE 2011
    Configuration in C:/system32/drivers/etc/services
    Sde.dll, pe.dll and sg.dll 64 Bit Version in FDO/Bin
    -Nik-
    Please use plain text.
