The default authentication for the WMS Server Administrator is
username: Admin
password: ChangeMe
You should definately change this as soon as possible if your server is open
to the outside.
If the testinstallation.html page worked for you, then the other test
samples should work as well. This is because it is pulling from the same
url. You should see that the testinstallation.html page has a field called
'Servlet Host', and this is by default set to
http://localhost:8080/liteview6.5/servlet/MapGuideLiteView, which is the
same url that you said didn't work when you called it directly.
I would guess that perhaps you didn't have Tomcat running when you called
the servlet directly? If you don't have Tomcat setup to run as a Windows
Service, then it must be running in a console window. As soon as you close
that console window, it will stop Tomcat.
Did you go through the installation steps described in the Liteview Servlet
Administrators Guide? The only other thing I could think of is that perhaps
you missed a step in setting up LiteView.
Navid
"Mohamed Yamani" wrote in message
news:41d26038_3@newsprd01...
> Hi,
> I am new to Mapguide liteview. I installed Mapguide 6.5 server, and
> Liteview6.5.
> I run MG server, tomcat server, and I open testinstallation.html and it
> was
> correct.
> Now, I want to open Wms administrator. I need a user ID, and password,
> which
> I did not find.
> I tried every password found in xml files in the litview server, but no
> one
> is accepted.
> Can any body tell me, what is the default user ID, and password for Wms
> admin?!!!!
> Also, I tried to run the test sample: http://localhost:8080/wmsviewer6.5
> but the map did not appear. I enter the server url as:
> but also no repsonse.
> I am sure that Tomcat is running correctly, and mapguide server, and IIS
> is
> running also.
> Do I need to run other services?
> Can anu body guide me?
> Regards
> Eng. Mohamed El Yamani
> Kemet Corp.
> www.kemet.com.eg
