• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise
    Member
    "SetupRepositoryIndices.bat" crashes after copying from 2010
    240 Views, 0 Replies
    02-29-2012 09:53 AM
    I followed the import instructions included in the 2012 help file.
    I backedup up, and restored the repositories in 2010, and then copied them over to 2012.
    When I run the SetupRepositoryindices.bat, it gives me this output, with a DBXML has stopped responding error, 3 times:
    Attempting to join environment: C:\Program Files\Autodesk\Autodesk Infrastructur
    e Map Server 2012\RepositoryAdmin\..\Repositories\Session
    Unable to join environment C:\Program Files\Autodesk\Autodesk Infrastructure Map
     Server 2012\RepositoryAdmin\..\Repositories\Session, creating a DB_PRIVATE envi
    ronment
    SetupRepositoryIndices.Script:1: openContainer failed, Error: MgSessionResourceC
    ontents.dbxml: container file not found, or not a container
    --- Setting up Site repository indices ...
    e Map Server 2012\RepositoryAdmin\..\Repositories\Site
    Joined existing environment
    Adding index type: edge-element-equality-string to node: {}:Name
    --- Setting up Library repository indices ...
    e Map Server 2012\RepositoryAdmin\..\Repositories\Library
    Adding index type: node-element-equality-string to node: {}:ResourceId
    Adding index type: node-metadata-substring-string to node: {http://www.sleepycat
    .com/2002/dbxml}:name
    Adding index type: node-metadata-equality-double to node: {http://www.autodesk.c
    om/MapGuide/Resource/Metadata}:smileyvery-happy:epth
    Adding index type: node-metadata-equality-string to node: {http://www.autodesk.c
    om/MapGuide/Resource/Metadata}:smileysurprised:wner
    Adding index type: node-element-presence-none to node: {}:Metadata
    C:\Program Files\Autodesk\Autodesk Infrastructure Map Server 2012\RepositoryAdmin>
    The three red lines are where it seems to crash.
    This is the error code that pops up when DBXML.EXE crashes.
    Problem signature:
      Problem Event Name:    APPCRASH
      Application Name:    dbxml.exe
      Application Version:    0.0.0.0
      Application Timestamp:    4d709422
      Fault Module Name:    ntdll.dll
      Fault Module Version:    6.1.7601.17725
      Fault Module Timestamp:    4ec4aa8e
      Exception Code:    c0000005
      Exception Offset:    0000000000053332
      OS Version:    6.1.7601.2.1.0.274.10
      Locale ID:    4105
      Additional Information 1:    add8
      Additional Information 2:    add89ebfcb1e4ee601913780718d8f3e
      Additional Information 3:    c08d
      Additional Information 4:    c08d6a2ef71a4544caf2b79187525492
    This is a Windows Server 2008 R2 64-bit, 4GB Ram, Virtual Server.
    Just to test, I restored the "default" repositories, and I still had the same crashes.
    Thanks for any help.
    Please use plain text.
