• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise Developer
    wilsonherrera
    error 404 when trying to access en.json from mobileviewer using .net
    719 Views, 1 Replies
    10-16-2012 01:35 PM
    hello everyone.
    i am working with the mobileviewer in AIMS2013, but i want to pass the map as a post and not as a get through a map catalog (to keep the path hidden from the user)
    sadly, whenever y try to add asp.net funtionality (c#) i got this nasty message (firefox web debug)
    Request URL:
    http://localhost/Default.aspx/localized/en.json
    Request Method:
    GET
    Status Code:
    HTTP/1.1 404 Not Found
    as you can see, this takes the page name instead of the folder, because of this is not able to find the .json files.
    i tried using the non compressed version of the mobileviewerSF.js, tried to hard-code the correct path, without success.
    you can see the error in the following image.
    is there a way to solve this problem? i was contemplating to embed the mobileviewerinside an iframe too, but this approach has another issues of its own (lack of iframe flexibility among devices is one of them).
    i also saw this thread http://osgeo-org.1560.n6.nabble.com/en-json-error-in-mobile-viewer-td4182802.html but after adding the .json mime type the problem keeps appearing.
    i dont know if anyone of you had any similar problem or know how to solve it, i would be really thankful if you can help me, or point me on a path that could solve my problem.
    thank you for your help,
    best regards,
    Wilson H
    Please use plain text.
    wilsonherrera
    Re: error 404 when trying to access en.json from mobileviewer using .net
    10-19-2012 09:32 AM in reply to: wilsonherrera
    i tried to replace this script
    var locale = mobileViewer.getQueryParam('locale');
    if (locale != null && locale.length > 0) {
    options.locale = locale;
    passing as parameter the url of the json file but without sucess.
    i only want to pass post requests to the mobileviewer (so the map path is not in the URL).
    hope anyone can help me with this.
    best regards.
    Wilson H
