• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk MapGuide Enterprise Developer
    Active Member
    db_log_buffer_full error
    662 Views, 1 Replies
    10-30-2012 11:04 PM
    Our map has more than 400 layers, and I see this errors very often from error log file:
    Error: An exception occurred in DB component.
    Db::smileytongue:ut: DB_LOG_BUFFER_FULL: In-memory log buffer is full
    Is anyway to set DB_LOG_BUFFER.
    we use AIMS 2012
    Autodesk Infrastructure Map Server (Version 2.3.0.5801)
    Autodesk Infrastructure Map Viewer (Version 2.3.0.5801)
    I tried to reduce some layers and see less this error on log file.
    Any solution?
    thanks!
    Nick
    Please use plain text.
    ADN Support Specialist
    Re: db_log_buffer_full error
    10-31-2012 10:33 PM in reply to: nick_xu
    If you are using AIMS2013,  try changing (increase) the highlighted below -
    [DBEnvironmentProperties]
    # DB ENVIRONMENT
    # This section is to set DB Environment. Determine the best sizes to improve the Server performance.
    LibraryCacheSize                   = 32
    SessionCacheSize                   = 2
    DBPageSize                         = 32
    DBXMLPageSize                      = 32
    LibraryLogBufferSize               = 12
    SessionLogBufferSize               = 1
    DBMaxTransactions                  = 1000
    SessionDBPageSize                  = 2
    SessionDBXMLPageSize               = 0.5
    DBTimeout                          = 0.2
    DBMaxLockers                       = 1000
    For AIMS 2012, you may need a upgrade, see this link : http://trac.osgeo.org/mapguide/ticket/1779
    Daniel Du
    Developer Technical Services
    Autodesk Developer Network
