• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise
    Valued Contributor
    nik.mazreen
    can't start infrastructure map server 2012
    700 Views, 8 Replies
    11-16-2011 09:40 PM
    I have a problem to start my infrastructure map server 2012 service. when i try to restart the services, it prompt this error --> "The infrastructure  map server 2012 service on local computer started and then stopped.some services stop automatically if there are not in use by other services or programs." i installed all my map server, web server and studio on my local pc and i already activate the license. but when i try to login to studio, it asked me to start the map server. when i try to start the map server, the error shown above pop-up.
    any idea??
    Th in advance.
    -Nik-
    Please use plain text.
    New Member
    johan.vandewauw
    Re: can't start infrastructure map server 2012
    11-18-2011 10:45 AM in reply to: nik.mazreen
    You can check the event viewer (control panel; administrative tools) for a clue. It may contain the error which was encountered, or check the log from map server itself Autodesk infrastructure map server 2012\Logs\Error.log
    Active Member
    ITSupport007
    12-02-2011 02:08 PM in reply to: nik.mazreen
    I had a probelm of not being able to load resources - "Operation not valid due to current state of the object". I Installed the recommended SP1's for 64 bit modules. I now have the new problem of the service starting up, then shutting down. I tried a delayed start and manual start on the service - same problem.
    I cleared the Event  logs. No new clues are given, just that the service is starting up, then shutting down. It would be nice to know what other service may be conflicting or missing.
    Thanks in advance for future assistance.
    Active Member
    ITSupport007
    12-05-2011 02:25 PM in reply to: johan.vandewauw
    The Infrastructure Map Server 2012 service entered the stopped state.  Event ID: 7036
    12-05-2011 05:11 PM in reply to: nik.mazreen
    Try running the server executable in interactive mode. Just run the executable from the command line with the "run" parameter. If it dies (like it did when it was run as a service), it may tell you why.
    - Jackie
    Active Member
    ITSupport007
    12-06-2011 07:33 AM in reply to: nik.mazreen
    Thank you. Unfortunately, no additional message. I uninstalled and reinstalled the entire package. The service is fine until the first reboot. After that, it starts up and quickly shuts down.
    Active Member
    ITSupport007
    12-08-2011 11:51 AM in reply to: nik.mazreen
    Uninstalled, then reinstalled. Did not add service packs. Services works fine. After Reboot, with services set to automatic, get Error Event ID: 7000
    "The Infrastructure Map Server 2012 service failed to start due to the following error:
    The service did not respond to the start or control request in a timely fashion."
    Same with (Delayed Start) to the Service.
    Able to start manually, after each reboot.
    Running on Windows 7 64-bit.
    03-20-2012 11:20 AM in reply to: nik.mazreen
    I'm having exactly the same issue with my IMS 2012 installation.  I have applied the latest service packs and everything was running normally, but after adding an alias in the Site Administrator the IMS service stopped.  I tried to repair the installation and do everything short of uninstalling and reinstalling the application.
    Can someone please post a possible solution to this problem that they may be aware of?
    03-20-2012 04:02 PM in reply to: nik.mazreen
    Solution:
    Un-install Autodesk Infrastructure Map Server 2012, and then re-apply service pack.
