Autodesk MapGuide Enterprise Developer
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Zoom to selection
- Highlight
- Email to a Friend
In codebehinde or js I need to select object and zoom to selected object. I use in JS:
function SetSelectionXML(selectionXml) {
var Fusion = window.top.Fusion;
var mapWidget = Fusion.getWidgetById(mgApiMapWidgetId);
if (mapWidget && mapWidget.isMapLoaded() && selectionXml.length > 170) {
mapWidget.setSelection(selectionXml, true);
But I have problem with zoom to selection object, because is zoomig to different place.
In loadMap.php have I also change code to:
$minScale = "5000";
$maxScale = 'infinity'; // as MDF's VectorScaleRange::MAX_MAP_SCALE
if($minElt->length > 0 && $minElt->length > 1)
$minScale = $minElt->item(0)->nodeValue;
Can you please help me?
Tenx!
Re: Zoom to selection
- Highlight
- Email to a Friend
If you are using .NET you need to call a server side page sending the MAPNAME, SESSION, LAYER, and "where clause" to receive the XML of the selected features.
You then use Javascript to take that XML to select the features and zoom to it.
Javascript:
var mapWidget = Fusion.getWidgetById('Map');
mapWidget.setSelection(myXMLReturnedFromServer, true);
the "true" actually zooms to the selected featue.
regards
gordon
- Highlight
- Email to a Friend
This blog may be helpful for you.
To Implement ZoomToSelection in Fusion Viewer MapGuide Enterprise 2011
http://www.cnblogs.com/junqilian/archive/2010/06/0
Daniel Du
Developer Technical Services
Autodesk Developer Network
- Highlight
- Email to a Friend
In some of case, we want to "zoom to selection"; this "selection" is not by mouse click; it's by "enter an attribute value" or "by the calculation result which match some specific attribute column value". In this case we need an example how to use "setSelection: function(selText, ZoomTo) function, what is the input parameters?
- Highlight
- Email to a Friend
You need the manually select the features programatically. For example you want the road with an ID of 20
You pass the SESSIONID, MAPNAME, KEY (20), KEYNAME (ID), LAYER (ROADS)'
to: http://forums.autodesk.com/autodesk/attachments/au
but you should use AJAX (try jQuery - http://api.jquery.com/jQuery.ajax/)
once the XML is returned from the page, you can call the javascript call
The "TRUE" will zoom to selected (unless it is a point - AIMS 2013 and AIMS 2014 changed so it just pans to points now and doesn't zoom)
