• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise Wishes
    Employee
    What should the next MapGuide be?
    226 Views, 11 Replies
    07-18-2006 12:43 PM
    Asking for your feedback. If you could take MapGuide in any direction you want for the next release, what would it be?
    Sara Makarenko
    Product Designer
    MapGuide
    Please use plain text.
    *Jason Birch
    Re: What should the next MapGuide be?
    07-18-2006 10:22 PM in reply to: sara.makarenko
    Hi Sara. Here goes:
    - Better support for unmanaged data sets!!!
    - Support for dynamic KML with implementation as good or better than
    GeoServer.
    - Focus on speed and stability.
    - Active Directory and LDAP integration
    - A more flexible, templatable front end. Better yet, adopt one of the
    existing Open Source web mapping toolkits such as Chameleon or
    MapBuilder as MapGuide's official front end. This would annoy existing
    developers to no end, but hey, you asked :smileyhappy:
    - Full support for important OGC standards such as WFS-T and SLD.
    - A full metadata storage and retreival service/front end that supports
    important relevant standards such as Z39.50 search, FGDC & ISO 19115
    (TC211) metadata, and OGC Catalogue Services. Population of this should
    be integrated into the Studio load procedures, and the metadata for all
    of the layers in any specific map should be should be readily available
    from the map legend and from the API so that a custom metadata index
    listing could be developed. Addition of information around unmanaged
    data sets should also be permitted. Contact information, Locations,
    Departments, Organisations, etc should all be normalized in the metadata
    store rather than stored independantly for each dataset.
    - GeoRSS support:
    - Ability to define GeoRSS URLs as data sources.
    - Ability to publish data sources as GeoRSS feeds (would need date
    column, number of latest entries to publish, expression builder for
    title and contents, etc...)
    - Collaboration tools:
    - sharing of current map state with other users
    - redlining/markup tools that allow markup sessions to be stored to
    the server, shared with other users (fine-grained authorization) and
    saved out as DWF and SDF.
    - integration with an open IM tool for spatial-enabled chat while
    redlining
    - Projection of rasters on the fly. Better projection support for WMS.
    - Enhanced server-to-server communication. Binary WFS??? Something to
    take the place of the client side multi-site capabilities of MG 6.5.
    - A cool "history" tool, with thumbnails of recent map states, allowing
    the user easy access to previous views.
    - A layer between Layouts and Maps, allowing many maps to be integrated
    into a single layout, with a drop-down list allowing choice between
    them. This layout->map lookup layer should maintain for each map:
    - Theme name
    - Map resource
    - Reset or maintain current extents
    - Active tools
    ... want more? :smileyhappy:
    Jason
    Employee
    07-19-2006 08:36 AM in reply to: sara.makarenko
    Hi Jason and thanks. Sure...more. :smileyhappy: Look further down the road. What do you want it to be in, say, 3-5 years. The big picture.
    Sara
    *Jason Birch
    07-21-2006 11:00 AM in reply to: sara.makarenko
    OK, but first a couple more short-term small picture goals:
    - Support Python at least at the API level (if not at the web UI level).
    You're already using SWIG, so this should be possible.
    - Isolate the API from the web. Currently, to deploy a client-side app
    that communicates with the server, I need to load an entire web config
    file with paths that should not be required. Think of MapGuide as a
    geo-server, not as a web server.
    Long term...
    Only one suggestion here, but it has lots of components: set up
    MapGuide as a full SOA geoprocessing server.
    - Include functions like reprojection, routing, network traces,
    geocoding, spatial overlays, proximity comparisons, reclassification,
    raster algebra, etc. All of the cool stuff that makes GIS GIS.
    - Expose these in the API, but also provide simple web service
    interfaces to this functionality.
    - Use standards such as XML, GML, JPEG2000 as a first priority. Use
    internal open mechanisms (such as AWKB) where it makes sense.
    - Set this up so that it can be used as a geoprocessing engine (either
    local or remote) for Map 3D, the MapGuide UI and API, and third-party tools.
    Give me a while, I'm sure I can think of more...
    Jason
    *Jason Birch
    07-23-2006 06:21 PM in reply to: sara.makarenko
    Hmm. Just thinking here... I wonder if it's reasonable to consider an
    abstraction layer, similar to FDO but allowing us to plug any number of
    geoprocessing engines into the back end, such as GRASS, FME, etc. You
    would probably want to provide a basic subset of functions with MapGuide
    to encourage others to build the providers/hooks for their own tools.
    There are license incompatibility issues, but as long as MapGuide is
    just providing the hooks it should be OK.
    You would probably want to keep the OGC Filter specification in mind for
    this.
    Jason
    Member
    07-24-2006 01:47 AM in reply to: sara.makarenko
    -- More examples in Manual
    -- More example to MapGuide Open Source, AJAX Viewer
    -- More source code of example page that work!
    -- split forum : MapGuide Open Source/ MG 6.5
    and translate this in another languages.
    New Member
    07-25-2006 10:41 AM in reply to: sara.makarenko
    Please post more ideas. As the product manager I'm capturing these ideas.
    Mainly I see a push for connectivity, shape MapGuide as aGeo Server not just a web publisher.
    Any comments?
    *Scott Friedrich
    07-25-2006 06:56 PM in reply to: sara.makarenko
    "Jason Birch" wrote Sara Makarenko
    wrote:
    ...Only one suggestion here, but it has lots of components:  set
    up
    - Include functions
    If you want to compete with ESRI's Arc GIS Server
    you must incorporate this functionality.
    simple web service
    In my experience, and with ESRI's - please
    concentrate on a .NET centric API.  I know this is going to cause reaction,
    but reality is what it is. ... MS got it right...constructive arguments
    welcome!
    If this OS approach takes off -  this
    whole OS move by Autodesk is a complete surprise to me having worked for a
    reseller for years.  I just hope Autodesk plans on putting as much
    resources on this platform as say, Inventor!?  Then, Redlands may have a
    problem.
    Scott
    *Jason Birch
    07-25-2006 08:31 PM in reply to: sara.makarenko
    Scott Friedrich wrote:
    > In my experience, and with ESRI's - please concentrate on a .NET centric
    > API. I know this is going to cause reaction, but reality is what it is.
    > ... MS got it right...constructive arguments welcome!
    The problem is that Autodesk is coming from an extreme minority
    position. Open Source is a large part of increasing market share. In
    order to do so, they need to support third-party developers that are
    working with the open source version, regardless of the platform or
    language. Supporting .Net to the detriment of PHP or Java would harm
    their ability to "compete" in the Open Source market.
    That said, the choice they have made to support SWIG is an excellent
    one. It allows cross-language delivery of a standard API, and also
    allows some language-specific custom implementations where it is
    warranted. I believe that this will go a long way towards supporting
    .Net. Also, it would be helpful if Autodesk could provide some
    pre-canned components that would allow developers to drag "maps" onto
    the design plane, possibly even within Atlas update panels :smileyhappy:
    Mapguide, as released, is a very solid foundation. I can't wait to see
    what comes in the future as part of an integrated geospatial strategy
    (please).
    Jason
    *clintonG
    10-05-2006 09:42 AM in reply to: sara.makarenko
    Jason -- you sure are knowledgeable about this topic -- I'm interested in a
    dialog with you regarding the use of RSS.
    <%= Clinton Gallagher
    NET csgallagher AT metromilwaukee.com
    URL http://clintongallagher.metromilwaukee.com/
    MAP 43°2'17"N 88°2'37"W : 43°2'17"N 88°2'37"W
    "Jason Birch" wrote in message
    news:5248516@discussion.autodesk.com...
    (please).
    Jason
