Autodesk MapGuide Enterprise
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
What is the point of mysql database
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
146 Views, 2 Replies
12-22-2009 05:02 AM
Hi
I am not sure how mysql database is to be used in Autodesk MapGuide Enterprise 2010. I have installed:
Thank you
- Mapguide server on win server 2008 (using apache and php)
- Mysql Server 5.0.67
- Autodesk Mapguide Studio 2010
Thank you
Re: What is the point of mysql database
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-22-2009 10:46 AM in reply to:
GeorgeGeorgiou3505
You don't _need_ mysql to run mapguide (it uses a filesystem based repository). However mapguide can digest MySQL as a datasource to display maps.
In order to display a map you will need.
- Datasource (this can be SDFs, SHPs, connections to database, etc)
- Layer (consumes the datasource and styles the information)
- Map (contains the layers you want to display)
- Layout (contains the information for the interface around the map and what maps to display)
(technically you don't need a layout if you don't bother with the included viewers)
In order for mapguide to work with MySQL you will need tables with:
- A primary key (this is used for the selection)
- A Geometry Column (I think there are geom, point, line, polygon, etc). Also you will want to build an index on this (I think it uses rtree by default).
You can also make an FDO schema from within map or civil or other tools. This defines the tables, coordinate systems, keys, etc. It is a bit more flexible the just making a table in an empty database but requires more configuration/maintenance.
Once you have that it _should_ show up in the layer on the drop down below the datasource. (Just note we haven't used mysql for awhile. So I might be wrong on some things).
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-05-2010 12:45 AM in reply to:
GeorgeGeorgiou3505
Thank you sakkaku. This information sure will be useful.
