Autodesk MapGuide Enterprise
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
*DaleB
WebServer Extensions Options
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
87 Views, 1 Replies
11-06-2006 11:51 AM
I'm going to have to get MGE2007 installed soon and I'm really floundering a
bit right now. Are most of you out there running on Apache or IIS? What
are the pros and cons of each, if any? Also, what are you using for a
scripting language, PHP, .NET? Again, what are the benefits and drawbacks
of each?
of each?
*Andy Morsell
Re: WebServer Extensions Options
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-06-2006 12:43 PM in reply to:
*DaleB
If your organization uses Windows servers, then setting up MapGuide with IIS
is the easiest and does not require as much "under the hood" configuration
as Apache does. Also, normally your organizational IT folks will mandate
what programming language(s) should be used. If you are using IIS, .NET is
a good choice since the two go hand in hand. If you are using Apache, then
you cannot use .NET and your choices are limited to PHP and Java. Of the 3
languages, PHP is probably the easiest to learn and use as well as
implement. Since MapGuide Admin is dependent on PHP, it will already be
installed and configured for you and you should be able to move forward a
with minimum of issues.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
"DaleB" wrote in message
news:5386686@discussion.autodesk.com...
of each?
Andy Morsell, P.E.
"DaleB"
of each?
