• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise
    *DaleB
    WebServer Extensions Options
    86 Views, 1 Replies
    11-06-2006 11:51 AM
    I'm going to have to get MGE2007 installed soon and I'm really floundering a
    bit right now. Are most of you out there running on Apache or IIS? What
    are the pros and cons of each, if any? Also, what are you using for a
    scripting language, PHP, .NET? Again, what are the benefits and drawbacks
    of each?
    Please use plain text.
    *Andy Morsell
    Re: WebServer Extensions Options
    11-06-2006 12:43 PM in reply to: *DaleB
    If your organization uses Windows servers, then setting up MapGuide with IIS
    is the easiest and does not require as much "under the hood" configuration
    as Apache does. Also, normally your organizational IT folks will mandate
    what programming language(s) should be used. If you are using IIS, .NET is
    a good choice since the two go hand in hand. If you are using Apache, then
    you cannot use .NET and your choices are limited to PHP and Java. Of the 3
    languages, PHP is probably the easiest to learn and use as well as
    implement. Since MapGuide Admin is dependent on PHP, it will already be
    installed and configured for you and you should be able to move forward a
    with minimum of issues.
    Andy Morsell, P.E.
    Spatial Integrators, Inc.
    http://www.SpatialGIS.com
    "DaleB" wrote in message
    news:5386686@discussion.autodesk.com...
    of each?
