• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk MapGuide Enterprise
    Using Wheel Button to Pan
    1055 Views, 9 Replies
    11-13-2007 11:06 AM
    How would I go about making it so that clicking the middle/wheel button on the mouse will enable the pan tool while the button is held down. (Like in AutoCAD, Map3D etc.)
    -Mike
    Please use plain text.
    Distinguished Contributor
    Re: Using Wheel Button to Pan
    11-14-2007 03:16 PM in reply to: mistermike
    Look for the OnMouseDown(e) and OnMouseUp(e) functions in ajaxmappane.templ
    That's where all the action starts and ends.
    - Jackie
    http://themapguyde.blogspot.com
    http://au.linkedin.com/in/jackieng
    11-15-2007 08:16 AM in reply to: mistermike
    Thanks for the reply.
    I found the OnMouseDown(e) and OnMouseUp(e) functions in ajaxmappane.templ, I'm just not sure what to do with them. :smileyhappy: I'm still kind of new at this.
    My Autodesk reseller is telling me it can't be done in the AJAX viewer (which is what I'm using, forgot to mention that). Does she know what she's talking about?
    Thanks again,
    -Mike
    11-18-2007 05:08 PM in reply to: mistermike
    I can't see why it could not be done.
    You are basically reusing the pan behaviour which is already implemented in the AJAX viewer, you just now have to hook that behaviour to a middle mouse click and release.
    Unfortuantely, I cannot show you how to implement it, because I haven't done it myself, but I do have a high-level knowledge of the internals of the AJAX viewer to tell you that such a thing is possible.
    Also, resellers usually aren't programmers and/or technically minded ;-)
    *James Murphy
    11-19-2007 01:04 PM in reply to: mistermike
    wrote in ...
    Jackie, you are starting to sound like Andrew D.
    We are trying.
    Murph
    The world is not FLAT so why is your GIS data?
    http://map3d.wordpress.com
    Active Member
    04-17-2008 07:51 AM in reply to: mistermike
    in the mousedown event, you have to check to see if it's the middle mouse button (these are different values for IE and FF...just google and you'll find this easy enough) then call the start pan function and on the mouseup, call the end pan function.
    Member
    10-01-2012 09:23 PM in reply to: mistermike
    Hi all.  Was wondering if anyone had done this change successfully?  I'd really love to enable panning with mouse wheel.
    many thanks
    Valued Contributor
    12-03-2012 11:20 AM in reply to: david.roy
    Would also like to know the solution
    thanks,
    New Member
    03-20-2013 09:00 AM in reply to: mitchellhastings1484
    Firstly, Thanks Jackie for telling everyone where to look, this was pretty easy, and I'm not great at Javascript
    I tackled this, and here is what I've got working...
    Looks like the placement is everything to make sure you check for middle before left/ right
    In ajamappane.templ....
    in OnMouseDown(e) before the check for Left Button Click, check for Middle Mouse
    function OnMouseDown(e)
        if(!PopupMouseDown(e))
            hidePopup(tbMenu);
            hidePopup(ctxMenu);
            hidePopup(infoMenu);
            parent.ForwardMouseDown(document, e);
        else
            return false;
        if(!mapInit)
            return false;
    // NEW CODE BLOCK START HERE
        if(e.which && e.which == 2) //2 is middle button in W3C/Netscape Which
    	StartPanning(e);
        else if(e.button && e.button == 4) //for ie, middle button is 4
            StartPanning(e);
    // END CODE BLOCK HERE FOR MIDDLE Mouse PANNING
         if(e.which && e.which != 1)
            return true;
        else if(e.button && e.button != 1)//for ie
            return true;
    Then in OnMouseUp(e)
    function OnMouseUp(e)
        var x = e.clientX - mapPosX;
        var y = e.clientY;
        try
            e.stopPropagation();
        catch(ex)
            e.cancelBubble = true;
    // NEW CODE ADDED HERE, BEFORE DIGITIZATION CHECK
    if(e.which && e.which == 2) //2 is middle button EndPanning(e); else if(e.button && e.button == 4)//for ie EndPanning(e); // END NEW CODE
    if(digitizing) { digitizer.MouseUp(e, x, y); return false; } if(isAlertShow) return;
    I didn't test it out with other redlining or digitizing continuous commands.. ie pan will digitizing, but for my needs, just panning with the middle button adds a tonne of user experience if other things break.
    Member
    03-20-2013 08:44 PM in reply to: mistermike
    Perfect!  does the trick, thankyou for posting.
