• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise
    *Jon Rizzo
    Using Map to connect to MapGuide WMS
    1778 Views, 21 Replies
    06-14-2007 01:09 PM
    I am trying to consume the WMS service provided by MapGuide. I am using Map
    as the client application. I am not sure if my problem is in Map or in
    MapGuide, so I am posting this here in case somebody has an idea.
    In AutoCAD Map (2008) I set up a connection to my MapGuide server. To rule
    out firewall issues, the MapGuide server is running on the same machine that
    I am trying to connect from. First, I set the coordinate system of the dwg.
    Then, I added a WMS connection in the Data Connect palette. Here is the URL
    that I am using:
    http://localhost/mapguide/mapagent/mapagent.fcgi?service=WMS
    After I click "Connect" I enter my MapGuide username and password. The Data
    Connect dialog then shows me all of the available layers. The only layers
    which are currently configured to show up are the Sheboygan sample layers.
    It doesn't matter which layer I select, the result is always the same: Map
    pops up a baloon warning that says "There was a problem adding data to Map.
    Failed to get bands data. Unable to connect to the host.".
    I find it difficult to believe that there would be a connection problem to
    localhost, so I must be doing something wrong. Am I skipping a step? Any
    ideas? Thanks in advance for any suggestions you can offer.
    Jon
    Please use plain text.
    Employee
    Re: Using Map to connect to MapGuide WMS
    06-15-2007 01:23 PM in reply to: *Jon Rizzo
    What you are doing should be valid Jon.
    If you were to try the WMS service in another client such as GAIA can you get it to work?
    You might want to post under Map3D instead as this may be a Map problem rather than a MapGuide problem.
    Dave
    Dave Wilson
    SQA Analyst
    AEC IM
    Autodesk, Inc.
    *Andy Morsell
    06-15-2007 04:57 PM in reply to: *Jon Rizzo
    I just tried the same thing in Map 2007 and did not have any issues.
    Accessing both an MGE and MGOS server. I thought the problem might be that
    you had tacked on the ?service=WMS (turns out map will do that for you, you
    only need to specify the mapagent), but it still worked for me. The fact
    that the WMS getCapabililties worked but the actual layer WMS request did
    not is sort of odd. It sounds like you are doing everything correctly so I
    wonder if it's an issue with Map 2008? Or, what if you don't set a
    coordinate system in the drawing? I would try that but I just discovered
    that I have a problem with my Map 2007 where I cannot set a coordinate
    system. Yippee.
    Andy Morsell, P.E.
    Spatial Integrators, Inc.
    http://www.SpatialGIS.com
    "Jon Rizzo" wrote in message
    news:5626896@discussion.autodesk.com...
    that I am using:
    Jon
    *Jon Rizzo
    06-18-2007 06:30 AM in reply to: *Jon Rizzo
    Hi Dave,
    Thanks for the reply. I just tried GAIA and I seem to have similar problems
    from there. I can browse the available layers & add them to a map, but the
    appear to be blank, so I guess my problem is somewhere in MapGuide. I
    disabled windows firewall client just to be sure & the problem persists.
    Here is the message log from GAIA:
    -------------------- Message #1--------------------
    CarbonTools.CarbonToolsException: Reading from WMS failed
    [Source URL = http://localhost:8008/mapguide/mapagent/mapagent.fcgi?]
    [Layer name = Samples/Sheboygan/Layers/Parcels] --->
    System.Net.WebException: Unable to connect to the remote server --->
    System.Net.Sockets.SocketException: No connection could be made because the
    target machine actively refused it
    at System.Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult)
    at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure,
    Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState
    state, IAsyncResult asyncResult, Int32 timeout, Exception& exception)
    --- End of inner exception stack trace ---
    at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult)
    at CarbonTools.Content.OGC.WMS.HandlerWMS.a(IAsyncResult A_0)
    -------------------- Message #0--------------------
    wrote in message news:5628192@discussion.autodesk.com...
    get it to work?
    Dave
    *Jon Rizzo
    06-18-2007 07:26 AM in reply to: *Jon Rizzo
    I have noticed that Map's coordinate systems and MapGuide's coordinate
    systems don't always play nice together on the same machine. For example,
    if you try to use one of the Arbitrary X-Y coordinate systems in Map, it
    throws errors when you save & open your drawing, at least it does for me.
    "Andy Morsell" wrote in message
    news:5628370@discussion.autodesk.com...
    system. Yippee.
    Andy Morsell, P.E.
    that I am using:
    Jon
    Employee
    06-18-2007 07:45 AM in reply to: *Jon Rizzo
    Within MapGuide if you build a WMS Connection, build a layer and add it to a map does it preview? That should help confirm if the problem is within MapGuide or not.
    Dave
    Dave Wilson
    SQA Analyst
    AEC IM
    Autodesk, Inc.
    *Jon Rizzo
    06-18-2007 10:35 AM in reply to: *Jon Rizzo
    I built a connection & the "Test Connection" button was successful. When I
    go to create the layer, I get a similar behavior to the other programs: I
    can see the layers listed in the "Feature class" dropdown, but none of them
    show any data in the preview.
    I had similar results on both my test machine and my production server,
    although I did not test a thoroughly on the production server. What's even
    more strange is that I can access external WMS services from my production
    server (such as jpl.nasa.gov) since it is in the DMZ , but I can't serve
    them up myself.
    wrote in message news:5629454@discussion.autodesk.com...
    MapGuide or not.
    Dave
    *Jason Birch
    06-18-2007 11:21 PM in reply to: *Jon Rizzo
    > from there.
    Jon,
    Have you used the MapGuide Site Administrator to update the WMS
    properties?
    The version that I have has port 8008 specified as part of the WMS
    server name. If this is the case for you, I think it will cause you
    problems, as you appear to be running MapGuide on port 80.
    You can also set this manually in Server/WMS/OgcWmsService.config.awd if
    you prefer using a text editor for configuration.
    Jason
    *Jason Birch
    06-19-2007 08:31 AM in reply to: *Jon Rizzo
    > properties?
    The reason I asked is because you specified your url as:
    And the error message references:
    Jason
    *Jon Rizzo
    06-19-2007 09:14 AM in reply to: *Jon Rizzo
    Interesting. Thanks for the tip! I didn't realize that MapGuide's default
    port would not work on a web server running on it's default port. This
    seems to make it "better" but something is still not right. In Studio, I
    created a WMS feature source connecting to JPL's WMS service & defined a
    layer with it. I am able access this layer from GAIA and display it on a
    map, using MapGuide as a sort of "pass through". This layer looks fine.
    Unfortunately, the layers defined in the sheboygan sample still don't seem
    to be showing anything. This time, GAIA is not recording any error
    messages, but the sample layers appear to be blank. Any ideas?
    Jon
    "Jason Birch" wrote in message
    news:5630885@discussion.autodesk.com...
    > properties?
    Jason
