• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise
    "URL activated for feature" link
    453 Views, 3 Replies
    11-05-2007 11:22 AM
    I'm trying to link some features in the map using the "URL activated for feature" in the layer editor. (MGE08, IIS)
    if I put www.google.com, then clicking on the map links to http://xxx/mapguide2008/mapviewerajax/www.google.com
    How can I remove the first part of the url? Why does it include it? Also, where can I change the setting for how I want the url displayed (new window, new tab, same window etc).
    thanks,
    -Mike
    Please use plain text.
    *Jason Birch
    Re: "URL activated for feature" link
    11-06-2007 12:09 AM in reply to: mistermike
    www.google.com is not a url :smileyhappy: Ok, it might be, but only in the context
    that MapGuide (or more likely the web browser) is interpreting it: as a
    relative url. You would see the same results if you used www.google.com
    as the value of the href attribute in an HTML anchor (a) element.
    You need to include the http:// part for it to work, and should really
    include the trailing slash as well.
    Back in the old days, browsers did not allow you to get away with typing
    the host name without specifying the protocol... then they clued in and
    assisted the users (and marketers) by making the assumption that most
    users of web browsers actually want to see a web site.
    Jason
    11-06-2007 09:06 AM in reply to: mistermike
    Thanks Jason, that worked just right.
    Member
    06-09-2010 02:34 AM in reply to: mistermike
    hi, I am using Mapguide Studio 2010. I want to add a link on my map on a specific spot. How Is it possible to add a button/text and assign a url to it?
    Thanks in advance
    P.S. the link is intendet to be external (not on the same server)
