• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise
    Active Contributor
    The remote server returned an error: (559) MgInvalidL​icenseExce​ption.
    350 Views, 3 Replies
    10-20-2012 12:07 AM
    Hi All,
    ServerActivator does not start also while login to studio encounter below error message:
    The remote server returned an error: (559) MgInvalidLicenseException.
       at Autodesk.MapGuide.Studio.Site.Comm.RequestManager.CreateSession()
       at Autodesk.MapGuide.Studio.Site.Comm.RequestManager.InitializeSession()
       at Autodesk.MapGuide.Studio.Site.SiteManager.InitializeRequestManager(String siteString, NetworkCredential credential, RequestManager rm, String& siteVersion, Exception& unKnownError)
    Actually, it is license activator which is not coming up. Hence, I am not able to activate license as well.
    Any idea on this please.
    Please note that, I have reinstalled the AutoDesk Infrastrcuture Map Server 2012 again but issue remains as it is.
    OS  Windows 2003 Server with IIS 6.0
    Anand
    Please use plain text.
    Valued Contributor
    ro_fr
    Re: The remote server returned an error: (559) MgInvalidL​icenseExce​ption.
    10-21-2012 10:39 PM in reply to: TATA_JUNE2007
    Hi Anand,
    did you try to start the License Activator? (Start>Programs>Autodesk>Autodesk Infrastructure Map Server 2012)?
    What happens when you try to start it? What does " license activator which is not coming up" mean?
    By the way - you mentioned that the server OS is W2003 - according to the system requirements W2008 is required.
    Rob
    Active Contributor
    10-21-2012 10:54 PM in reply to: ro_fr
    Rob,
    When I  go Start>Programs>Autodesk>Autodesk Infrastructure Map Server 2012>Launch Autodesk Infrastructure Map Server Licensing Activator
    This does not launch the license activator!
    Also, I have OS Windows 2003 server. Does it okay to installed Autodesk Infrastructure Map Server 2012?
    Anand
    Valued Contributor
    ro_fr
    10-22-2012 12:38 AM in reply to: TATA_JUNE2007
    Hi Anand,
    have a look at Windows EventViewer - maybe further information can be found there why the serveractivator.exe doesn't start.
    Not sure if this is the reason but AIMS 2008 requires W2008 as OS, not W2003.
    Rob
