• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise
    New Member
    Highscreen
    The User ID or Password is invalid. Please try again!
    541 Views, 1 Replies
    10-14-2011 05:34 AM
    i have a problem if I connect to the MapGuide Server using MapGuide Studio.
    I get this error:
    "The User ID or Password is invalid. Please try again!"
    I use this adress to connect:
    http://localhost/mapguide2011
    with the user:
    Administrator
    and the password:
    admin
    If I connect using Maestro I got the error:
    "unauthorized"
    The system ist:
    - Windows 7 x86 Ultimate (english version)
    - .NET 4.0
    - MapGuide 2011 Enterprise x86 (german version)
    - MapGuide 2011 Update 2
    The MapGuide Server is using a IIS configuration with .NET. My application which is using MapGuide is running and the site administrator, too.
    I can´t only connect to the server by using studio or maestro.
    On the system php is not installed.
    Any solutions?
    Highscreen
    Please use plain text.
    ADN Support Specialist
    Re: The User ID or Password is invalid. Please try again!
    10-23-2011 07:37 PM in reply to: Highscreen
    Please make sure you are using .net framework 2.0 for your application pool of MapGuide. it may be 4.0 by default if you installed .net framework 4, while MapGuide has not been upgrade to 4.0 yet.
    Daniel Du
    Developer Technical Services
    Autodesk Developer Network
