Autodesk MapGuide Enterprise
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
TBWeb Fusion Help
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
599 Views, 9 Replies
11-28-2008 07:15 AM
I don't see a Topobase Web group and since it is built on MGE I figured this is the best place to look for help. Running Topobase Web 2009 SP1. I can get a basic layout to display topobase data fine, but when I try to use the Fusion layout (which I really want to use) I get AJAX errors (see attached)
Re: TBWeb Fusion Help
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-28-2008 07:26 AM in reply to:
hhiggins
If you use FireFox you will get the details of the AJAX Callback error which might help. The second dialog suggests there is a problem with the overviewmap. Is your overview map set to the same as your main map? Do you have a copy of MG Studio so that you can create a simpler map and use that as the overview as a test?
Dave
Dave Wilson
SQA Analyst
AEC IM
Dave
Dave Wilson
SQA Analyst
AEC IM
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-28-2008 07:37 AM in reply to:
hhiggins
wow thanks for the quick response!
I tried FireFox and have attached the error i receive with it. The Map and Layouts are from the package that TBWeb provides as a sample. The Map doesn't have any layers so not sure how much simplier I can make it. Not sure what an overview map is compared to a regular map. I do have a copy of MG Studio 2009.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-28-2008 08:04 AM in reply to:
hhiggins
i found some stuff in Access.log...
<2008-11-28T11:00:20> Administrator CreateSession.1.0.0:0() Success
<2008-11-28T11:00:25> Administrator GetResourceContent.1.0.0:2(Library://Layouts/Flexi ble.ApplicationDefinition,) Success
<2008-11-28T11:00:25> Administrator GetResourceContent.1.0.0:2(Library://Topobase Web Layout/Map.MapDefinition,) Success
<2008-11-28T11:00:26> Fusion Viewer 192.168.74.100 Administrator GetResourceContent.1.0.0:2(Library://Layouts/Flexi ble.ApplicationDefinition,) Success
<2008-11-28T11:00:28> Fusion Viewer 192.168.74.100 Administrator GetResourceContent.1.0.0:2(Library://Topobase Web Layout/Map.MapDefinition,) Success
<2008-11-28T11:00:28> Fusion Viewer 192.168.74.100 Administrator SetResource.1.0.0:3(Session:949836e8-ffff-ffff-800 0-0050568d721b_en_7F0000010AF20AF10AF0//Map4930159 c02831.Selection,MgByteReader,MgByteReader) Success
<2008-11-28T11:00:28> Fusion Viewer 192.168.74.100 Administrator SetResourceData.1.0.0:4(Session:949836e8-ffff-ffff -8000-0050568d721b_en_7F0000010AF20AF10AF0//Map493 0159c02831.Selection,RuntimeData,Stream,MgByteRead er) Success
<2008-11-28T11:00:28> Fusion Viewer 192.168.74.100 Administrator SetResource.1.0.0:3(Session:949836e8-ffff-ffff-800 0-0050568d721b_en_7F0000010AF20AF10AF0//Map4930159 c02831.Map,MgByteReader,MgByteReader) Success
<2008-11-28T11:00:28> Fusion Viewer 192.168.74.100 Administrator SetResourceData.1.0.0:4(Session:949836e8-ffff-ffff -8000-0050568d721b_en_7F0000010AF20AF10AF0//Map493 0159c02831.Map,RuntimeData,Stream,MgByteReader) Success
<2008-11-28T11:00:28> Fusion Viewer 192.168.74.100 Administrator SetResourceData.1.0.0:4(Session:949836e8-ffff-ffff -8000-0050568d721b_en_7F0000010AF20AF10AF0//Map493 0159c02831.Map,LayerGroupData,Stream,MgByteReader) Success
<2008-11-28T11:00:29> Fusion Viewer 192.168.74.100 Administrator GetResourceContent.1.0.0:2(Library://Topobase Web Layout/Map.MapDefinition,) Success
<2008-11-28T11:00:29> Fusion Viewer 192.168.74.100 Administrator SetResource.1.0.0:3(Session:949836e8-ffff-ffff-800 0-0050568d721b_en_7F0000010AF20AF10AF0//Map4930159 d11c63.Selection,MgByteReader,MgByteReader) Success
<2008-11-28T11:00:29> Fusion Viewer 192.168.74.100 Administrator SetResourceData.1.0.0:4(Session:949836e8-ffff-ffff -8000-0050568d721b_en_7F0000010AF20AF10AF0//Map493 0159d11c63.Selection,RuntimeData,Stream,MgByteRead er) Success
<2008-11-28T11:00:29> Fusion Viewer 192.168.74.100 Administrator SetResource.1.0.0:3(Session:949836e8-ffff-ffff-800 0-0050568d721b_en_7F0000010AF20AF10AF0//Map4930159 d11c63.Map,MgByteReader,MgByteReader) Success
<2008-11-28T11:00:29> Fusion Viewer 192.168.74.100 Administrator SetResourceData.1.0.0:4(Session:949836e8-ffff-ffff -8000-0050568d721b_en_7F0000010AF20AF10AF0//Map493 0159d11c63.Map,RuntimeData,Stream,MgByteReader) Success
<2008-11-28T11:00:29> Fusion Viewer 192.168.74.100 Administrator SetResourceData.1.0.0:4(Session:949836e8-ffff-ffff -8000-0050568d721b_en_7F0000010AF20AF10AF0//Map493 0159d11c63.Map,LayerGroupData,Stream,MgByteReader) Success
<2008-11-28T11:02:22> Administrator GetResourceData.1.0.0:3(Session:949836e8-ffff-ffff -8000-0050568d721b_en_7F0000010AF20AF10AF0//Map.Ma p,RuntimeData,) Failure
There is a failure on the last line.
Hope that helps.
Hope that helps.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-28-2008 08:05 AM in reply to:
hhiggins
and here is the corresponding error message in Error.log...
Error: Resource was not found: Session:949836e8-ffff-ffff-8000-0050568d721b_en_7F 0000010AF20AF10AF0//Map.Map
StackTrace:
- MgResourceServiceHandler.ProcessOperation line 80 file d:\buildforgeprojects\carrera_nightly\build_33.7\e nt\os\server\src\services\resource\ResourceService Handler.cpp
- MgOpGetResourceData.Execute line 124 file d:\buildforgeprojects\carrera_nightly\build_33.7\e nt\os\server\src\services\resource\OpGetResourceDa ta.cpp
- MgServerResourceService.GetResourceData line 1401 file d:\buildforgeprojects\carrera_nightly\build_33.7\e nt\os\server\src\services\resource\ServerResourceS ervice.cpp
- MgApplicationRepositoryManager.GetResourceData line 1201 file d:\buildforgeprojects\carrera_nightly\build_33.7\e nt\os\server\src\services\resource\ApplicationRepo sitoryManager.cpp
- MgResourceContentManager.GetDocument line 590 file d:\buildforgeprojects\carrera_nightly\build_33.7\e nt\os\server\src\services\resource\ResourceContent Manager.cpp
- MgResourceDefinitionManager.GetDocument line 476 file d:\buildforgeprojects\carrera_nightly\build_33.7\e nt\os\server\src\services\resource\ResourceDefinit ionManager.cpp Resource was not found: Session:949836e8-ffff-ffff-8000-0050568d721b_en_7F 0000010AF20AF10AF0//Map.Map
StackTrace:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-28-2008 10:02 AM in reply to:
hhiggins
If you open the Flexible Web Layout in Studio you will see many tabs. One tab is for the main map and another is for the overview (the small insert map that most flexible web layouts enable by default). When a flexible web layout is created the main map is assigned to the overview map until the user creates a simpler more practical map for the smaller insert. The overview map is designed to be zoomed out further than the main map giving the user a point of reference of where they are in the main map. The session not found errors are not a huge concern other than you are getting an actual error from IE which is annoying.
When you say your map doesn't have any layers then how does the sample preview? An empty map is likely to generate errors in a flexible web layout.
Try taking an actual map that has at least 1 layer in it and create a new flexible web layout in Studio and play with that to see if you get errors.
Dave
Dave Wilson
SQA Analyst
AEC IM
Dave
Dave Wilson
SQA Analyst
AEC IM
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-28-2008 10:45 AM in reply to:
hhiggins
i created a new map, flexible layout and layer. the preview of the layer works great. the preview of the map won't work because the refresh button is not active. the web preview of the flexible layout fails. i've attached screenshots of these errors...
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-01-2008 12:04 PM in reply to:
hhiggins
i found out what the problem was. in my map i didn't have the x,y populated. once i did that problem went away.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-01-2008 02:15 PM in reply to:
hhiggins
It's odd that the system can't query the bounds on your data. That should have been set when adding a layer to a new map. If it doesn't there may be a problem with the data. What format is it in, SDF, SHP or coming from a database in this case Tobobase? If the data is coming from Oracle then Oracle usually require that the bounds of the data are set in the user_sdo_geom_metadata table. I would have assumed Topobase is setting this.
Dave
Dave Wilson
SQA Analyst
AEC IM
Dave
Dave Wilson
SQA Analyst
AEC IM
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
09-17-2012 11:31 AM in reply to:
hhiggins
I am having that same problem I can't get the map to display on IE 8. Any ideas?
